- Thread starter
- #1,301
Justin DuBois
DSM Wiseman
- 3,347
- 3,319
- Aug 15, 2019
Oakland,
California
oh - ohhh it's just a global click away...
Before I start - Global fuel has to be correct. I want to set Global Fuel once if I can, and then check it now and again. To check if Global Fuel is correct, I need the RPM ramp to pass through the peak of the VE map, and for my intake, that looks to be 5000rpm at 15psi. - Hence the lower boost WGSDuty. The number in the VE cell at the peak I want at 98-100, and all the rest of the cells should be something less. (If I do it right)
I'm building a new SD map to calibrate for any boost level, so I'm about to make lots of pulls at various boost levels as I work through as much of the WOT map as I can get to.Curious about your methodology here? Why drop the boost level instead of calculating for your desired boost level and adjusting fuel to correlate to that?
Don't want to insult your intelligence since you clearly know what you're doing (and you probably know this), but you're aware the ECU is pulling data from multiple cells at one time, not just looking at a singular cell, right?
