Street Build ITFLYS - 1Gina2G
ITFLYS - 95GSX 2.0L 6-Bolt Crank with 2G pistons, 1G TopEnd, with 2Gb-CamSensor and a Kiggly-CrankSensor - TD05H-Bastard 20G - E85 w 1000cc inj. ~25psi. Street driven track day car.
Awesome!
My drawing is kind of ambiguous down where I wrote in 2½ and 3½" for where the flap goes to, and I can't get a decent check on that with it in the car. But your O2 sensor is probably in a little different position anyway, since manifolds and O2 housings are different.
I never did tie down the bottom end of it to keep it from fluttering. So 3/16" clearance to the O2 sensor is about what's needed to keep it from ever hitting.
Gonna see how the paper template fits. Maybe there I can fingure out a stand-off and bolt solution for an additional hold down.
No, the 15deg clip on the turbine blades are effective to address excessive spike, and creep.
Ok thanks. That's kind of what I was afraid of though. You did apparently feel that something needs to be done beyond just gathering up all the Mitsu parts and putting them together. That something was clipping the turbine wheel.
So, what got me asking you this is, @athlete3344 in this thread in post #15, is asking basically if he should go external wastegate to avoid boost creep, or if he should stick with the internal gate on the TD05H turbine housing and just try to put together a better actuator than what he has.
I hate to try to tell him what to do because I haven't done much with the Mitsu turbos, and I see the potential complications multiplying already. He has the awesomeness of a brand-new looking TD05H-20G turbo that has just been sitting around doing nothing for a long time, but a no-fit actuator.
Want to take a look at his question in post #15? Nobody has tried to answer it yet.
I did go with a billet internal WGA, so that I could increase the spring pressure. At Redline, the minimum boost I have is ~16-17 psi. I have not used an external myself.
I’ll take a look at the thread.
Before I swap out the alt, I check if the template fits.
Looks workable, might see where a standoff could go.
I’ve got the E3 o2 sensor routing out the top, so there is no clearance issue there. I will also look at one less cut and bend for the 2G o2 sensor routing.
Awesome that you won't need that lower flap to clear an O2 sensor.
On my car I do a walk-around before and after every drive (like you would do with an airplane) and one thing I always look at is the clearance there, between that flap and my O2 narrow band, to make sure the heat shield isn't rotating.
It did rotate from vibration at first which is why I added that trick to the upper heat shield (for the PS pump) which is what keeps it from rotating. But in your case, if you find a way to hang onto it down lower someplace, that will be terrific because it should keep it from rotating and would also reduce flutter!
Latest alt install was successful, 14.1v consistently, and the thing drove wonky, with hanging idle. Thinking maybe voltage is different (better?) than the previous and the fuel trims are moving. after a long drive it started to settle - The CombinedFT SD adjust moved the SD numbers richer.
One shot at it
Back at high boost mode, AFR alignment is also still good - and I'm very happy with the slight adjustment at the 2K and 2.5K cells where the turbo is lagging in the SD table to get the low RPM close to target. That is a difficult area of the table to grab data.
My Vehicle registration to RADwood has been accepted under the Track Toys catagory.
Tuners was full
I wonder if your timing started to drop earlier, the turbo would spool faster. The way it drops from 2500-3500 is very satisfying, I just wonder how it would behave if that started at about 2000rpm. I know that's generally out of normal vehicle operation so maybe it isn't worth the effort to find out.
The way that it goes super rich after 7000rpm is interesting to look at. If adjusting the cell on the SD table at 7500 to a value of 80 or lower would fix it, would show how the turbo efficiency falls off the table past 7000rpm.
Log looks great, good stuff.
  • For sale 4G63 Auto T Cases
    (2) 91-96 Auto Tases $200 a piece + shipping & paypal fees(1) 97-99 Auto T Case $200 +...
  • Wanted WTB: 2G EDM Taillights
    Looking on getting a pair or be pointed in the direction of where to buy.-Thanks
    • late_dsm
  • Wanted 2g WTB - 2G Cluster
    Looking for a donor 2G cluster for a project.
    • rwmagee90
  • For sale 1g 1g FWD 3speed design scattershield
    1g fwd shield
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $35 each. Message 702-741-6987.
