Street Build ITFLYS - 1Gina2G
ITFLYS - 95GSX 2.0L 6-Bolt Crank with 2G pistons, 1G TopEnd, with 2Gb-CamSensor and a Kiggly-CrankSensor - TD05H-Bastard 20G - E85 w 1000cc inj. ~25psi. Street driven track day car.
@Justin DuBois FWIW running a sheetmetal intake is the only reason I switched to a COP setup. I haven’t had any problems with mine since I switched. I’m using 300m coils.
As long as your valve cover has all its mounting points still intact and not missing half the threads.
-Daniel
Where does one shop for COP setups?
I have seen some 1G Guys just cut up the bracket. You only should have to notch it, and if you wanted from there just box it/have someone weld it. But I've never seen a cut bracket bend. The 1G guys have to grind the lower tab of the intake that the coil pack mounts to, and cut the intake manifold bracket, just to fit the A/C compressor so I've seen it done.
The coil pack bracket though, I'd honestly just relocated it. You could probably get a custom one fabbed up fairly cheaply. If you've got access to a MIG, just make an H out of some cheap bar stock, drill/tap holes, and move your 2G coils onto the bracket. Should be fine.
Don't use the coilpack that came with it. It's a 90 DSM style and is supposed to work in conjunction with the OEM 90 Tach Filter.
Or just go COP. I myself like a good COP setup, but if you're trying to look OEM-ish, wouldn't be too hard to find an OEM looking spot for the factory coils on the intake itself.
P.S. those scratches and how beat up the paint on the Cyclone looks hurts my heart, deep into my very soul. I worked so hard on that paint. F*ck USPS and their employees. I said what I said.
I feel ya on the paint, but don’t despair. This unit is going to be completely stripped and powder coated with new gaskets and shaft seals.
Rich is about to make it look incredible. That's exciting. Gonna go with the same black/red?
It’s going to depend on how well it strips down. The factory silver aluminum look would work quite well here, the only thing is, I already went with black on the throttle body
Here's how it looked before I painted it. I did a little smoothing(mainly on rusty parts/oxidized spots) but it wasn't like bead blasted or anything.
Hopefully that gives you an idea of what's waiting underneath.
The whole COP thing has been going on for 20 years now with mediocre results. All that happened was someone figured out that they worked and everyone went for it because it wasn't stock and was visually better. That was the only two criteria for doing the mod. BUT, they sucked compared to stock and needed an ignition box to make work acceptably. Big red flag. Meanwhile the stock coils paired with an ignition box has gone 8s and supported 4-figure power numbers.
Keep in mind we cannot adjust dwell with the stock ECU, so the mod is kinda like throwing in some weird aftermarket 450cc injectors on a car with a stock ecu and no piggy back, then using an ignition box like a safc just to make things normal again. I really don't see a benefit and would be shocked if you did it Justin.
When the Evo went with it - I thought - hmm. The heat on the head is bad enough, and then to put a coil there? I thought - hmmm, that better be some quality engineering to hold up.
Today its really just an idea for how to address the limited space. I'll have to address that eventually
The machine shop 1G head has returned populated with the 1G valves and Evo springs with spacers. I will need to extract a broken exhaust stud from one corner. Sam at Bay Area Cylinder Head is only charging me for the replacement core 👍🏻
I have two scrap 1G heads here - not sure what to do with them.
When I ran a cyclone , used a 2g coil slightly modified above the actuator. It needed a small support made from aluminum and the plug wires were a little leggy but it worked really well and had acceptable clearance. Used a t25 actuator under where the CP is mounted. Your going to love the cyclone when boost comes on it totally changes the flavor of the pull.
I started to get some of the broken tool out of the M8 stud with 1200rpm tungsten carbide bit on a Dremmel, but given the lack of control on the outcome I decided to stop and take the head back to the machine shop with M10 studs for the corners.
I showed Sam the mess I made worse, and handed it back to the pro for the stud extraction and upgrade.
The head is back! - I've reached step 3
The broken exhaust stud was repaired to an M8 stud. I guess that was cheaper than installing two M10 upgrades? and I cleaned up the gasket and bolted on the intake manifold. I see I will need some leveling washers if I'm to use the 2G hoist bracket. The 1G manifold is a little different than the 2G here, its not flat on the backside of the flange.
Heh, after playing around, I think the best way is to use one washer between the bracket and the head, and bend the bracket to make the bolt holes sit flush
Step 1 - remove rt foot shoe.
Nobody talks about how lifting the head into the engine with the car on stands is done.
I put a stool underneath in the gap between the radiator and turbo, so that I can stand on a chair and slide a shoeless foot into the gap to stand on the stool, straddling the front bumper.
Then I can crouch down and lift the top of the engine onto the block, while using the head stud holes as a site line for the dowel pins.
What is the torque wrench setting for the 4 - ARP Exaust mani to Turbine mani bolts?
STM - ARP Bolt Kit
STMKIT-TMBK-BKDSMOE
Stock is 55-65nm
and I checked them, clicks at 60nm - no movement. That means I already exceeded that with a hand wrench.
