We're on Boost
- 3,047
- 1,468
- Aug 25, 2007
Seattle area,
Washington
Finish, as in, Done? But ..... those words are never spoken here!20G Build - Finish.
Finished, is what happened to the clutch - Done is what I am with the 20GFinish, as in, Done? But ..... those words are never spoken here!
.This sounds like some sort of funky DSM haikuTest Drive - notes
the steering is effortless
find a smoother road
don't push so hard in the curves
these tires suck
Do you mean it's 14.7 even when it shouldn't be 14.7?My last logs have a wideband steady at 14.7 - aaaaAaaah !!! all the time?!
Correct, WOT 14.7. It was wrong.Do you mean it's 14.7 even when it shouldn't be 14.7?
Sunroof glass and a regular GoPro suction cup.Well I watched it about 5 times. That was fun.
How do you have your camera mounted there? It seems good, like it's not wiggling around, and the field of view is just about right.
Could you show a pic of how you have it mounted?
Oh darn it I don't have a sunroof - no glass on the roof.Sunroof glass and a regular GoPro suction cup.
If I had a solid roof, during the body shop phase I would have a threaded standoff welded to something under the head-liner and then cut a neat hole in the headliner to bolt the camera mount in place. The hatch glass is farther back than you think. I’d need a longer extension to extend forward from the hatch, loosing stability.Oh darn it I don't have a sunroof - no glass on the roof.
Have you ever tried it sucked onto the hatch glass? Then I guess you'd swivel the whole arm thing forward instead of down, to get the cam more forward. Ever tried that? Seems to me it would wiggle more with the arm horizontal going forward?
Yeah probably not good.The hatch glass is farther back than you think. I’d need a longer extension to extend forward from the hatch, loosing stability.
Somewhere between the sun roof, and the rear hatch is best - this is medium wide from the rear hatchYeah probably not good.
Thanks for the pics there! The side view of it attached to the hatch glass really shows it well.
Is medium wide like a zoom setting on the GoPro?this is medium wide from the rear hatch
Yeah, there are lots of different camera modes. I find medium field of view is lower distortion than wide with the a good amount of peripheral image.Is medium wide like a zoom setting on the GoPro?
Someone else who speaks camera! Yes. Photoshop is another example. Dodge and burn tools, unsharp mask etc.. The digital realm inherited most terminology from its analog progenitor.Yup, a "35mm equivalent focal length" of about 50 mm. That's about what I like for most shots, and that's pretty much the definition of "medium". Then if I want even less dimensional distortion, like when shooting some car part, I might use a mild telephoto zoom of around 70 to 105 "35mm equivalent focal length".
Remembering back to 35mm film days, it was the same. The way different focal lengths worked out for that format got baked into photographic thinking, and that's why today we still see the "35mm equivalent focal length" usually shown in our camera software.
Those numbers are for when the zoom is done optically, with the lens. When it's done digitally like in a cell phone, with no change in the lens, then I don't know what happens!
The "equivalent" thing is what most of us are doing with our air/fuel ratio gauges too. We are not resetting the gauge to read true AFR for E85 or whatever. We are leaving it set to read "gasoline equivalent" AFR. It's fine!
Right!I had a whole spreadsheet to calculate the actual stoic of e85 and everything in between, only to learn it wasn’t necessary.
Windows closed. Audio is a mic in the camera - which could be made remote with the right mic and USB connections.Yeah that looks pretty good. In my car I'd want to be able to see the shifter in all positions, and what the left and right feet are doing (would have to go by watching the knees but that's ok), and my gauges and tach which are all right out there on top of the dashboard so they are easy. It would be just about like what you have there for cam position and wide/tele setting.
Oh I finally remembered - in the video you posted Oct 6 there is really no wind noise or wind buffeting noise. Does that mean all the windows are completely shut?
