Is light crank scoring ok?
John Mark Dongon
5+ Year Contributor
94
5
Feb 7, 2019
Stoccton, California
I don't want to disassemble and buy a whole new crankshaft if it's not all that bad. It's light scoring I can feel with my fingernails. It's overall more smooth than scoring tho. The 3rd journal is not scoring just dirty.
you might be able to get by with having it polished. You should take it to a machine shop and have them check it out
The point is why the op is doing this. I remember that he said in his other post that he rotated the crank a couple of times by hand then some bearings got damaged because of dirt/debris. So our suggestion would be the same like we already recommended him that clean everything up and rebuild properly with good parts.
Agreed.
May be that it's dirty, but that #3 journal looks undersized and the finish looks poor. Still could just be whatever goop is on it.
At minimum the crank needs to be taken out, properly cleaned, checked to specs and machined if possible. Issue is it may not be worth it, just have to pull it and see.
Thats crank is done, short of you machining the journal undersized which some say is not recommended , it is unusable. Notice he similarities?
This has been continued from the OP's previous post below. "cleaned" comes from there. @ThunderChild didn't mean only for the crank.
https://www.dsmtuners.com/threads/crankshaft-connecting-rod-wiggle-play.522141
Idk know what to make of this.......all good though man
edit: got it now, had to read that a few times
all I know is that looks like some NAR NAR to me
Look around for a parts car or partout. you could find a crank way better than that for a couple hundred or even less if your patient. I picked up a clean never torn down shortblock for 150 last summer, for example.
Agreed, and being a 7-bolt it's far easier to find a good crank than a 6-bolt.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
