Is this idle ok?
Have you tried doing a seafoam intake treatment? Had a similar issue. Changed plugs, wires, did intake treatment, oil treatment, and changed oil. Problem hasn't come back in 8,000 miles at least.
And also what everyone else said. Switch to the NGK's instead of AutoZone's cheapo plugs.
What is the correct voltage it cycles at? I think I remember it chilling at .2 and sometimes .3 but when I plugged it in near a different plug it read .2 to .7. I'll have to do another log because I figured out one of the plugs was CC motor. I'm grabbing some NGK's tomorrow to see if that helps at all. The idle is getting better from fixing the starter grounf but it still breaks up bad during boost. It's an in and out of boost feeling.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
