Slippi84
- 4,454
- 20
- Jun 8, 2005
Cinnaminson,
New Jersey
Marty quoted me at $219.95 per raxle.
Is that for race axles?
WTF driveshaft shop wants 1200 for stage 3's which are rated to 525 these things are pretty much bulletproof from talking to the guy at raxle with lifetime warranty that's nuts.19psi Pump Gas + Methonal on our shop Evo 9 here. Running the 2.5L taken out of our rally car after X-Games last year
Jeff
That is the T4 S366 - its a pretty crazy motor (2.5L custom crank, 10.5:1 compression pistons, etc - not the ideal motor for this turbo but we figured we had everything here might as well try it out) so we didnt crank the boost up yet - but it will probably see some race gas and 6-700hp pretty easily
The HP curve was still upward sloping at redline so this would be ideal for a 2.0/2.1L setup
Jeff
- we had a t3 50 trim on the car (no meth) and on pump gas we made 395whp at 15psi and we couldnt get it to go any higher without knocking - sooooooooo the solution was methanol and a giant turbo
Yep- we had a t3 50 trim on the car (no meth) and on pump gas we made 395whp at 15psi and we couldnt get it to go any higher without knocking - sooooooooo the solution was methanol and a giant turbo
Jeff
Yes - but remember we are running almost 10.5:1 compression pistons - with normal pump gas on a 2.0L I dont see 22psi being an issue at all.
Sending you a PM about the HX40 setup
Jeff
It's not theory. A manifold that does not separate pulses paired with a twinscroll turbo spools slow. The only purpose in running a twinscroll turbine is to keep the pulses separated. Tim runs a DNP Performance T04 Exhaust Manifold. I don't think he's telling you this just to discourage you. But just to warn you, if you're unhappy with the spool speed. And to say that it can be remedied.
WHy upgrade to a bigger turbo and aim for the same power? Agreed that is about the limit of a stock block but hell gotta upgrade sooner or later try and break the stock block record if you been having that good of luck so far.
Yeah, if you end up going with a welded center differential, you will not need the viscous coupler; instead you will need the viscous coupler eliminator to hold the output shaft in place. Talk to Shep and discuss your options.
Approximate Pricing:
AEM EMS w/ sensors $1650
Raxles RACE axles $400
Fuel System $700 (injectors, fuel pumps and hoses/fittings/filter/wiring, etc)
Intercooler and custom piping $1200
Intake and Filter $170
Transmission $2800-3000 (Shep Stage 3 with REM or Cryo and welded diff)
Clutch $1150
----->$8270 subtotal.
Twicks, I know that you have suggested I switch from the dsmlink/maft setup to AEM in the past, and I realize it is a restriction, but like I mentioned before, People have run 8's with a dsmlink/maft setup in the past and I have already spent $700 on dsmlink and $250 on a wideband and I already own a 3.5" gm MAF, so I'm looking at $250 for a MAFT and couplers vs $1700 for the AEM setup. I just dont know if I can justify dropping all the extra cash on my limited budget when the ecu I have can probably get me to my goals. If you really believe the maft will be that big of a restriction I guess I could sell my used dsmlink stuff, but I'm gonna take a big loss on it.
I already have custom 3" short route IC pipes and the dual fuel pumps are done, so It sounds like I need an IC core,bigger injectors, DNP t4 mani, Tial BOV, Tial WG, PTT clutch, gt4088, intake and filter, raxles, a custom vband 02 eliminator downpipe and a tranny. Shep Quoted me $2600 for the stage 4 with REM and I can get a 4spider if I want it, but he recommended against it for some reason. I think I'm over budget!
It's theory until you try it, and then it becomes practice.
dsm-onster... since you're not talking theory, could you tell me about your experiance?
I know my partially divided manifold is not ideal, but how much is it going to help? How much is it going to hurt? Will a 90% divided turbo/manifold set-up, be better than having no division at all? Would mostly separated exhaust pulses help spool a turbo better than no separation of the exhaust pulses? Would a divided T4 manifold work better with a open T4 turbo, or would a open T4 manifold work better with a Divided turbo? Is the only purpose for running a twin scroll turbine to keep exhaust pulses separated, or are there any other benefits like faster exhaust velocity that might help spool?
I asked Steve93Talon if he was talking from experiance for fair reason (I don't know if "Tim" is the same guy as Steve93Talon or not). As a Wiseman you know there is alot of "talk" on tuners that is not back by experience. I have to protect myself from that kind of stuff, so thats why I asked if he was talking from experience. I appreciate any and all comments, but at the same time people shouldn't expect me to take every comment as law... especially if they have NO experience to back-up their talk. Thats fair enough right?
If either of you have some experiance that would help me.... I'd love to hear about it. I'm sure we all would. On the other hand we can talk about theory all week long, but real world numbers always seems to differ. Maybe we'll just have to wait and see what happens when I put all this theory into practice huh?
I think its safe to say I hit 500whp with the FP3065, but it wouldnt do that on 92oct pump gas. I want 500whp on 92oct pump gas.
I never thought about trying for the stock internal record. I'm not much for dyno racing. Dyno number can be fixed so easily its ridiculous. But it might be fun to "claim" I have top stock #'s
Even for FWDAxles -- contact Marty at Raxles ( Raxles - Raxles Home ) and tell him that you are looking at the same ones that Tim Zimmer has -- they are the Raxles RACE axles. You will be shocked how much less they are than the driveshaft shop, and they have a lifetime warranty against breaking -- they break or damage, replaced for free -- for life. Period.
.Stop hijacking my thread people, he needs to buy a divided mani... end of story.![]()
What's the cheapest high quality intercooler core that will support 700+ whp?
Can I stick with a cheap DSMlink/maft setup and still reach my goals or will I have to ditch it for an AEM to make 700+ with a 4088?
Anyone have dyno numbers from DSM's running an s370 or s374 ... anyone? ...anyone? .... Bueller? ....Bueller?
I've seen a 2.3L with T67 + DSMlink + GMMAF @ 550-600whp.
If you really want 700whp, you're going to have to go AEM. No doubt about it.
The amount of options that AEM has over DSMlink is tremendous. You love it
Oh really? I guess ya better tell the guy making 730whp on a Mustang dyno with DSMlink then...
http://www.jeffgst.com/mattdyno.wmv
Or the guy who's gone 8.47 @ 169 on DSMlink. Or the countless others in the 9s with it.
"Like what"? ....you're really letting your light shine huh?Like what name some ?
What should I tell him then..... Steve? You seem to know it all. Why don't you tell him whatever the heck you were thinking about ....I sure don't knowOh really? I guess ya better tell the guy making 730whp on a Mustang dyno with DSMlink then...
I was trying not to be a dick when I asked you to name some but I see steve said what I was thinking without watering it down I second the
How about like everything ....Thats what AEM does
So let me get this strait.... Instead of "trying not to be a dick", you decided to go ahead and be a dick, because Steve93Talon said what you were thinking (dick thoughts), and you didnt want him to be the only dick, so you 2nd his dick-ness?
I'll tell you what I give atoo..... I give a
to jerkoffs that can't give their honest opinion, without bashing others people opinion .....It's pathetic
No siht there are cars using DSMlink that go fast ...So what?
There are DSM using EVO3 16g that goes 10's, but does that mean that a 16g is the best for 10's? .....no
unlmtdndeavor your right about EMS being better but you keep bringing up nitrous as a reason why its' better no one said anything about nitrous. How much power did you pick up in your low range area? I'm not saying your not a good tuner but plenty of people have seen very minimal gains from going to ems so maybe you just needed someone with more dsmlink experience give it a hack on your car.
