twicks69
Supporting Vendor
- 4,314
- 2,035
- Mar 12, 2004
Milwaukee,
Wisconsin
That is just nuts
If you don't mind me asking do you do your own tuning because that seems like some VERY good results both pump gas and race gas. You have the best of both worlds 50trim like spool and big turbo power.
The tuning was done by myself and Luke Stubbs of Beyond Redline Performance on his dyno using AEM EMS and an AWD DynoJet with dual eddy current/weather station/WB O2 setup. Essentially, I put together the map, then we tweeked it together on the dyno. Either way, Luke really knows his stuff and he is the reason I know as much as I do about it.
I'm not a great mechanic, so I don't enjoy pulling out my transmission constantly and I certainly don't wanna spend 7k on a dogbox transmission that I would probably hate driving on the street.
. But like I said if it's not a everyday car and you can #### it do it.
They're a NJ based company who specialize in DSM's
Thanks to the rest of you for giving your answers and opinions as well. Twicks, were those numbers you posted made with the newer head with 288s or the old head w 272s? My 2g head is unported and has not had a valve job, however, it has been hot tanked and has all new factory size valves and fp3 cams as well as a new set of fp dual valve springs and retainers. I had originally planned to buy a new cylinder head or have a valve job and port work done to my current head as one of my last mods, but the shop that is tuning my car right now is telling me I should have a valve job and port work done before I bother with any other upgrades (turbo, manifold etc..) because they say "the upgraded head is where you will make all your power". Do you guys think I should stick with the head I have or upgrade? Also, my engine is not o-ringed, but it does have arp head studs and a cometic HG. Is o-ringing and using an MLS HG necessary to push 40+psi, and if so can it be done without me having to pull the engine again? I have about 9k that I can spend on the car right now, and by the time I upgrade the turbo, maft, axles, injectors, a bigger intercooler, transmission, differential, misc drivetrain parts, a little bit of labor, and a clutch, I don't know If I'll have enough money left for a head upgrade. What should I spend my money on with my limited budget?
Your a brave man to use such a wicked turbo setup on stock internals, I'll be very surprised if your engine stays together for long with a 4088, but at least you will have an excuse to go all-out if it blows up. Even on pump gas you should be able to squeeze out 450+ hp. Let us know what kind of power you make once you get her back together.
