Holset Part # Thread Only!!!!
just bought a holset this weekend numbers are
kit 3800400RX
assy 3538221
serial 1271327
i am almost positive it is a hx40w correct me if im wrong im new to holsets any info i would appreciate
I have a H1C that I can't identify. Assy # 3531667
High Tech Turbo said its a 56mm compressor wheel but I thought H1c's had at largest a 54mm?
H1C - 3531667:
Compressor wheel: 56mm inducer, 83mm exducer
Turbine Wheel: 70mm inducer, 60mm exducer
I found this HX40W for sale locally. Its brand new and has these numbers but I didn't see these in this thread:
Assy: 3533132
serial: C 03204517
Customer 3802825-00-09/6
Model HX40W
Found out it was an 8-blade compressor, 12-blade turbine.
I didn't see the assy# or Kit number listed... Guessing it was an HX40W and later someone added the billet 6 blade comp and comp cover? It was sold tome as an HX40 Pro. I picked it up on some diesel truck forums for $325 shipped. Feels very tight bearing wise. I'm happy with it...
I'll get pics up tomorrow.
Holset tag states:
Kit-4955660RX
Assy - 4044175
SN - M1427459
18cm divided T3 rear housing. I'll get rear blade dimensions tomorrow it is soaking now.
Numbers on rear housing are:
E4-01-164, 3537638
Cartridge # is a 3530521.
Has a billet 6 blade comp. 60mm minor , 83mm major.
Comp housing:
2" ID discharge
OD inlet is 4" , ID- 3.60"
At first glance, The comp housing looks physically smaller than the HX35 just had? Maybe it's just the older style inlet... :confused:
I got my hx40 off of ebay yesterday. My ASSY# 3594289 and my cust.# 3594290. The tag on the compressor says HX40W and its an 8 wheel. Other than that the seller said it came off a cummins generator, which I looked up and that partnumber has it pegged for a generator. I hope there are not too many variations cause I have not found any other information anywhere else. I hope this helps someone:hellyeah: one day.
This should be enough to give any forced induction enthusiast a turboner, whether you're a Holset fan or not.
Brand new 60mm/86mm 7-blade billet HX40 compressor wheel. These things are cut so precisely that hardly any balance correction is necessary at all....I've seen evidence of this in prior billet Holset compressors, as well as the BatMoWheel that is currently in Dave's turbo.
Look closely and you'll see one tiny balance correction around the outer perimeter, around .5mm in total depth. That's it.
The part number on this particular wheel is 4044562 for those who are interested, but be ready to lay down some Ben Franklins at your local Cummins dealer.
That bad boy is comin to my house..
If Lucas doesn't like that then there is no hope. LOL
I have supposed hx40 in bep but I cant seem to find these numbers anywhere and i looked through the counterfit slideshow but mine seems legit :(
any SERIAL 50840217
assembly 4041276
TAG is normal looking with the volvo logo made in sweeden on it blue rivited on almost impossible to read the model number :( ill post a pic up later today any help would be awesome.
hmm thinking shes real HX40W 4041276 VOLVO D7/D7C
Hey guys someone near me is selling a "new holset hx35w" and i would love to know some information because i can not find much
ASSY# 3597508
SERIAL# HO60306458
MODEL# HX35W
Which WH1E/H1E comes with
Turbine
76.00mm Inducer
67.00mm exducer
Complete Unit Number will help greatly.
