Drewpy Dawg
- 271
- 304
- May 18, 2008
Sachse,
Texas
Is there any advantage to using a high resolution CAS disc if I am not using a standalone ECU or looking to do sequential ignition? Does it make tuning any easier or help smooth idle or any other conditions? I’m using a 3G ECU with ECU Flash so I’m guessing the timing map could be tweaked to work with the high res disc, but I haven’t looked into that or if it’s even worth the effort. Just curious about the possibilities.
