2G Help choosing valves
screwlegg
5+ Year Contributor
34
Jan 27, 2018
Sebring, Florida
So I'm looking at the Brian crower site for some valves and they have some different sizes just wondering which size to get if I just want to run everything basically stock. Just trying to replace old bent valves
Pic below vvv
If you bent valves chances are you cracked the guides. The cost to replace guides and valves usually isn't worth it on a stock head. It's usually cheaper to just buy another head.
Wow just checked how much they cost. $300 just for the valves I don't even want to see how much guides cost. :( could you please recommend any 420A heads on here. I like this community and would like to give back to it
Just use normal replacement valves. You said you are running stock. I just had my head refreshed after my timing belt slipped and bent my cyl 2 exhaust valves. I ordered $15 each valves through NAPA. Replaced the two that hit, valve job on the rest, and decked the surface. The car runs great. I bent mine without damaging guides, but I would recommend having yours checked.
$200 bucks to have it professionally checked, parts that needed replaced, replaced, a valve job and surfaced deck. Thats the way to go.
There's an eBay seller named engnbldr that sells oem + oversized valves and guides. He's out of Canada I believe. Despite selling on eBay, there not typical eBay quality, and very wallet friendly. :thumb:
