Help choosing BOV
kanderson111
103
6
Mar 12, 2005
El Dorado, Kansas
I've recently replaced my turbo and done supporting mods, upon testing for boost leaks I discovered my stock BOV leaks at about 15 lbs. This is ok for now but I will be turning up the boost as soon as I order my FMIC. My question is what kind of BOV will hold up to 24 lbs of boost and can still recirculate. I was looking into the Greddy type S, but I don't know if this one can recirculate. Any help or suggestions would be appreciated.
The Greddy Type-S does recirculate and you will not be disappointed with it's holding power or sound.
--Anson
--Anson
Might be tough to find one too so you better start looking they are discontinued now. I had to buy an RS and mod the thing to recirc. Appearantly there is a kit now to do it.
http://www.extremepsi.com/store/customer/product.php?productid=17767&cat=0&page=
theres a link to the greddy type rs its for a 95-99 but has both recirc and vented option for $6 if you ever plan to do a MAFT blow through or you can just buy the recirc with it for normal price
also another BOV you might wanna look at
http://www.extremepsi.com/store/customer/product.php?productid=18013&cat=404&page=1
you may need to buy a recirc kit through HKS i believe
another suggestion
http://www.extremepsi.com/store/customer/product.php?productid=16158&cat=402&page=1
i have the RFL with my maft setup and im pushing 20 psi on my e3b16g, never had a problem with boost and sounds mean as hell :thumb:
hope this helped
Thanks for the help guys. The reason I have to make up my mind pretty quick is because the FMIC kit I'm ordering from Slowboy, asks for the BOV flange type you want welded on. Im leaning towards the Greddy because there is no extra charge for the Greddy flange, and it sounds like people are pretty satisfied with it.
I would say get a tial and never look back but if you dont have a maft go with the greddy. The type s is great. look for one on ebay.
eww do not get the Greddy...
Honestly you should get a hks ssqv and the recirc kit is cheap...
Otherwise I would say a Tial
Go with the Greddy Type RS-I just installed it and it works great. It has a larger valve than the Type S (40mm vs. 37mm) and a stronger spring. I have a full hardpipe w/Greddy flange, so I just purchased the Universal Greddy Type RS BOV Kit ($179) and the outlet adapter ($15).
You can get it at: www.prostreetonline.com
    • george bromwell
    • pma1123
    • Sdcryan1
