turbodsm18
- 675
- 4
- Jan 26, 2005
816/417,
Missouri
Ok, So tonight me and my roomate went out to tune his car....Well, we got anxious and threw some E-85 in the bi***...It was a mix of about 2 gallons of 91 octane and about 6 gallons e85. ( The car is now gonna be strictly e85)
I will start out by saying, the car pulls freaking hard at 24 psi on a Turbonetics 50 trim......But heres what we are confused on...
I cant post a log because his laptop runs linux and his wireless card is not work so he cant send the log to me.
But.
The car is seeing a peak timing of 15.xx degrees at about 7K rpms. At 24 psi the IDC are showing 76% (he bought the injectors used and he was told they were 780cc injectors). The car is seeing no knock whatsoever.
Heres a problem....The Aem gauge shows about 12.8:1 AFR and Link is showing about 10.5:1 AFR
I believe the global fuel setting is right at 342 and the dead time is right at 315....
So my questions are: Should we read from the Aem gauge or from Link...(by the way, we are old school and I believe he is still on V1)?
What should we be seeing for peak timing on 24 psi.....(this is still on a bone stock(internally) 7 bolt)?
What AFR should we tune for on E-85.....(ive been reading to tune for about 12:1)?
All help is appreciated...
-Kevin-
But.
-Kevin-
but through different posts I've skimmed through, that seems about right to me as well. I believe I've read of guys running as high as 24-25 deg without any issues (though don't think I'd try this without concrete info first). I know with just meth injection & pump I currently run 19deg without issues & as far as I know you can expect abit more out of E85.
