Gm Translator HELP
FilmerDude
201
6
Nov 10, 2014
Temperance, Michigan
Ok so I got this gen 1 translator from a friend and I was wondering what this plug and sensor is? Sensor has a vacuum port and the plug looks like o2 not sure. Anyways there is also a white wire coming off the translator what does that go to? I know how to plug in the rest. Also I'm going to be running this with Link v3lite so how would I go about tuning with the translator and link?
I've never seen those sensors/connectors before. Can't help you there.
As for running with v3lite, just zero out all the knobs on the translator and use link for all the airflow adjustments. The white wire is to tap an RPM signal but if you have Link you don't need it.
Also, IMO, I would sell the translator, upgrade to v3 full, and run ECMLinks direct GM MAF cable.
Get some better pictures. Close up of front and back. Disassemble the connector shown and take pictures facing the pins. Maybe others can help.
