turbosax2
Moderator
- 4,482
- 673
- Nov 19, 2006
Mechanicsburg,
Pennsylvania
I did an alignment on my car yesterday and ran into an interesting problem.
Some history:
I replaced quite a few components in the front end of my car a couple years ago, including the inner and outer tie rods. Inners came from MachV and outers were OEM. I did my own alignment then with string and jack stands and all was well. Because I had the power steering rack out, I paid special attention to make sure the steering wheel was centered, and the tie rods had about the same amount of adjustment on either side.
Forward to yesterday:
I put a whole slew of new suspension components on and did an alignment on the car again with SmartStrings. The car hasn't been driven much over the past couple years and all the tire rods looked in excellent shape. The front was lowered a bit (~14" from center of wheel to fender) and the camber was set to -2.5*. The first time I tried to adjust the front toe I got:
Left: 0* (but could adjust down to -0.5* if maxed out)
Right: +0.8* (maxed out)
After bashing my head against the wall quite a bit, I decided to check to verify the steering wheel was centered in it's throw. Using an angle gauge, we found that it was slightly off by one spline. So we adjusted that to get it perfect. Then, trying to adjust toe again:
Left: +0.1* (maxed out)
Right: +0.1* (maxed out)
In spec, but I can't get zero or negative toe.
So...the only thing I can think of is that the inner tie rods are too long! I took an outer tie rod off and verified the threads go the whole way into it, so I couldn't tap any more. So besides cutting the inner tie rods shorter, I'm stumped. Perhaps the ones I got are actually longer than OEM ones. If anybody has OEM ones laying around, I think I have another new set of the MachV ones here we could compare.
Some history:
In spec, but I can't get zero or negative toe.So...the only thing I can think of is that the inner tie rods are too long! I took an outer tie rod off and verified the threads go the whole way into it, so I couldn't tap any more. So besides cutting the inner tie rods shorter, I'm stumped. Perhaps the ones I got are actually longer than OEM ones. If anybody has OEM ones laying around, I think I have another new set of the MachV ones here we could compare.
