Bedicine
- 542
- 189
- Jan 3, 2022
Toronto,
ON, Canada
Hello,
So i discovered I had a leak in my exhaust manifold where it bolts to the motor. Ended up pulling everything and two of the bolts snapped (ARP) where the manifold meets the turbo housing. I tried everything to get them out but they were too low inside the housing to do much with. Ended up drilling the first hole and got the bolt out and can retro it. Due to the angle and trying to drill out the second one I’m now not lined up and won’t be able to tap the hole.
Can I weld these holes over and re tap them without it being an issue? Option two I guess would be getting a new hot side, can I go with any td05 7cm? This might be a time to go with an external gate or I change complete directions and go bigger turbo.
Thanks everyone and happy holidays
