gofer
Moderator
- 8,165
- 1,556
- Feb 18, 2006
South Gilbert,
Arizona
It is E85.
11.605 at 126mph on pump gas. Full boost 2800-3000 rpm depending on gear. No special parts needed to bolt it on. You buy it, you bolt it on, you run 126mph, you drive it home on pump gas.
Pulls were done on a dynojet.
EMS - Evo ecu
Engine - 6 bolt bottom end, BSE, 20 over??? top line pistons, FP2 cams, stock intake manifold, NT throttle body
Fuel - E85
I think I'm getting a good amount of power out of this turbo. I went 126mph on 93 octaneat 25psi.
I'm getting lost here danl, what fuel are you running exactly? I keep seeing pump and then the next post I read its E85 or you keep mixing it up?With 420 on a dynojet I went 122 mph. Then I added a little bit of timing (still on E85) and went 124mph a couple weeks back.I also wanted to add that I think my results are inline with others.
You must have some freak ass car, my setup isn't putting up near as good of trap speeds as your car with nearly the same setup but I'm on 100% E85 and running 30psi.
Her is a vid from the shootout....
