gofer
Moderator
- 8,165
- 1,556
- Feb 18, 2006
South Gilbert,
Arizona
That does seem a bit late in the RPM band looking at peak torque in the dyno printout, as a comparison here's my dyno running 28psi on a stock 7-bolt block and FP2 cams on E85. HTA68 with TD05H wheel and 7cm hotside.
Interestingly enough, although peak torque's pushed 1k later in the RPM band peak horsepower is still right ~ 6.5k. Seems like a good trade off on this little turbo considering the 60whp gain, I'd like to know more about your setup too if you don't mind Tony? Were you playing with cam gear timing too, maybe?
You wouldn't happen to have log?
after 5years of owning it.
I just can't cut decent 60's........
