aether
- 3
- Jan 14, 2012
Aberdeen,
Maryland
This is my first time post on this forum... I've read through my manuals over and over, and I've searched around all the dsm forums looking for similar resolved issues to no avail. I'm a little confused right now and don't know if I should track down a new pump, another ECU, or maybe a CAS (it seems like those cause similar issues, though I think the ECU would throw a different diagnostic code).
Here is the problem and what I have done so far (everything is in chronological order):
The car starts up great every time, but dies after 5~20 seconds (usually closer to 5 than 20). It runs smooth and when it dies it does it smooth and immediately, just like turning the car off normally.
I tested for boost leaks, and couldn't find any.
I then tested fuel pressure by modifying the banjo bolt on the fuel filter with a swagelok fitting that can be capped when not hooked to a gauge. The fuel pressure went to spec (~27 psi) as soon as I started cranking and maintained proper pressure for a few seconds, but then started losing pressure quickly and then the engine just died like normal.
I then hooked a voltmeter to the fuel pump power wire at the fuel pump electrical harness in the trunk. As soon as I start cranking the fuel pump is getting 14V and it maintains 14V for a few seconds while running, but then the voltage to the pump drops to 0V just before it dies...
I then pulled the ECU and fuel pump relay. The relay tests fine, all the proper voltages and proper continuity/discontinuity when energized/unenergized. I opened up the ECU and it looks OK. I talked to my buddy who I got the car from, and he said he had the ECU caps replaced less than a year ago by one of the electrical engineers at our work.
I then put both the ECU and relay back in the car and hooked up a test light to read any diagnostic codes. It gives a code 42 (fuel pump).
Does the ECU have some way of determining power draw of the fuel pump? If the fuel pump is going out, or drawing too much power, or getting too little power, will it trip this code and cause the ECU to turn off the pump?
Any help or a nudge in the right direction would be much appreciated.
Thanks!
Thanks!
