99gst_racer
Moderator
- 12,010
- 1,707
- Apr 5, 2003
Coloma,
Michigan
The engine is a stock 7-bolt.
In the middle of a spirited drive last week, my car jolted and bucked similar to hitting fuel cut. Then a large puff of black smoke rolled out of the tailpipe.
The car still starts and drives, but I am know experiencing a knocking sound. I'll try my best to describe the sound. It's a third of the loudness of rod knock, but 3 times louder than lifter tick. Sounds like lifter tick on roids. The noise is very consistent and RPM dependent, and it amplifies with RPM.
I immediately pulled the valve cover, but nothing was out of order. Cam caps are tight, lobes look great, lash adjusters and rocker arms are in place, and oil is circulating throughout the head like normal. I also have good oil pressure. We turned the engine over by hand, and verified timing. The marks line up correctly, and tension is still correct.
The engine does not leak, burn, or push any fluids at all. We drained the oil , expecting to see metal shavings, but we were wrong. The oil was still clean and free of any foreign material.
I did a compression test a few days prior, and I got 175-170-170-165. I'm going to do another compression test in a couple hours on my lunch break, so I'll report back with that.
A few days prior, the car was throwing a code for "cylinder #3 misfire", and I never did trace the problem. I could clear the code, shut off the car, and restart, and she ran like a champ - no more misfire.
One more notable detail - when turning the crank manually, it seemed to hit a "hard spot" that required much more energy to turn past.
What else should I do or look for? We're probably going to pull the head soon if I can't figure this out. Anybody else got any advice or tips? I'm thinking there could be a problem with a valve, but I can't understand how it could have happened.
