95GSXBLUR's Eclipse GSX
Mitsubishi Eclipse GSX
SBR Sheet Metal Inake, 60mm Custom Throttle Body, Borg Warner S258 Bolt on, SBR Front Mount, Stainless 2.5" Intercooler Piping, Stainless 3" Turboback Exhaust, Ported EVOIII O2, FP Exhaust Mani Ceramic Coated (o2 and Turbine housing), Dejon 3" Intake, FIC 1600cc Injectors, Walbro 255lph Fuel Pump Rewired, Aeromotive Fuel Pressure Regulator, Tial BOV, Magnecore 10mm Wires, Custom B&M Aluminum Oil Cooler, Stainless Fuel lines(tank-filter-rail-reg -6an), Stainless Oil lines, Custom Oil filter Relocation, Custom Power steering cooler
Mods-Engine
SBR 2.4L G4CS Stage II Block, 4G64 Crank, Manley Rods, Wiseco 8.8:1 Pistons, ARP Hardware, 1G Stage V ported head, BC280 Cams w/ Manley Springs/retainers, Nitride SI Valves, Revised lifters.
Mods-EMS & Logging
DSMLINK V2, 3" MAF-T, PROSPORT EGT Peak/Hold, BOOST Peak/Hold, Oil Pressure Gauges, Hallman Pro Manual Boost Controller, APEXi Turbo Timer
Mods-Drivetrain
SS Clutch line from Master to Slave (SBR) PTT TWIN DISC
Megan Racing Strut Bars, Enkie RPF1s, BFG KDW 234/45/17's, KYB GR-2s, Eibach Pro-kit, Brembo Slotted/Drilled Rotors, Axxis Pads, SS lines, ATE "Blue" Break Fluid
Parts Wishlist
Slight body work & Graphite Grey Paint.
10 Sec Time Slip
True Coil-overs
1/8 Mile E/T
8.052
1/8 Mile MPH
94.750
Timeslip Photo Link
Timeslip Details
Track Name : US 41 Dragway
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 3180
Tires : Street Radials
Sponsored Car : no
363.0 lb/ft
Dyno Type
Dynapack
Dyno Shop Name
Slowboy Racing
Dyno Session Details
Nitrous : No Nitrous
Turbo : V-Trim
Boost : 18
95GSXBLUR
More in 2G DSM
Share this Vehicle
