1990TSIAWDTALON
Moderator
- 13,309
- 11,364
- Nov 14, 2013
Independence,
Kansas
Has anyone tried a MBC style setup on the vacuum/boost source to slow it down or speed it up to adjust the "slam open" mode?
Just a thought.
Just a thought.
I have one of these Cyclone IM laying around, is it worth it? Gains vs Evo 3 IM?
E3 has 2G size runners, Cyclone has 1G size runners.I have one of these Cyclone IM laying around, is it worth it? Gains vs Evo 3 IM?
(When both runners are open)E3 has 2G size runners, Cyclone has 1G size runners.
Right. The only point to make here is which ones match what. E3 bolts up to a 2G head, where the Cyclone bolts up to a 1G head.(When both runners are open)
I think I found a logDo you have a datalog of this?
Airflow is smooth.I think I found a log
Ignore the VEs, I was doing some (extreme) testing because run over run I was getting inconsistent WBO2 -- the point where I would see a need for +/- 8% adjustments each time. So I was forcing more fuel to see if it became more consistent and it saved a DA table update. I fought my FIC-750's pulse width abnormalities for years and never won. but that doesn't matter now. The car's been disassembled since 10 days after this log anyway and now I'm on high-z 1200s.
Anyhoo, under 3000rpm and >20psi with only one runner it seemed to cram more in from the b16g than could slip past the valves..
I could push >20psi as long as there's enough rpm even with one runner only (more stable boost level).
There's only one ve table in link.I wonder if two ve tables would be useful.
My TPS would read 0.65 after warmup (0.63 consistently was an impossibility), ISC of 38, CombinedFT <5%, but max would only allow 4.84v. The attached log shows no adjust. I'm switching out TPSes this year, I think I have a spare or two.Airflow is smooth.
Why is TPS not adjusted?
It is weird that you're a full point rich AND adding that much airflow. Why did you make that adjustment?
Your SD table values are ridiculous and that's excluding what you said above. If you're lacking fuel to the point of making idle 63.x, you're treating an airflow adjustment as a fuel adjustment. Adjust the base fuel pressure and/or global fuel instead.
Anyone got a pic if the JDM compressor(s)?From another thread - AC brackets. The JDM AC bracket on the right looks like it will clear the Cyclone intake support bracket.You must be logged in to view this image or video.
