Spyder 4g63 cyclone motor in 2g dsm
Quent
4
Nov 3, 2020
Cincinnati, Ohio
Hey so I found this motor cyclone intercooler engine 6 bolt can my 2g ecu work? And is the motor a direct plug and play into my 2g spyder? There claiming its from a 1990 eclipse but it looks like a galant vr4 engine to me
Ecu doesn't care what motor. It does care what sensors, injectors, hard electronics etc. It doesn't know what block, head etc you have. Easiest solution is use the parts from your car unless for some reason yiu can't (cas comes to mind). If that happens research those needed changes.
