1G Can I prime oil through the head turbo oil feed?
Can't you just unplug the injectors and turn the engine over a couple times to prime it? Or pull the fuel pump fuse? Or spin the oil pump if the timing belt isnt on yet?
If you're worried about the cams, I'm sure the assembly lube will protect them enough before pressurized oil reaches the head.
Yes you can but seems like a lot of screwing around. I always just unplug the cas and turn it over and look in the oil fill for fresh oil. Simple and no screwing around with adapting crap to the port.
*If* you have a pre-lube tank priming tool yes you can lube thru the head oil feed.
You just have top adapt it out to fit & seal.
That way you can prime it up right before initial crank.
Most road race cars I set up have an accusump system installed so they have a reservoir charge tank on board.
New motor time is easy prime after the tank is pressurized.
So if your spending big money on engines these tools are kinda cheap.
