Turbo feed line has no oil during prime
Denji
Supporting Member
1,123
18
May 4, 2004
Calabash, North Carolina
Hey guys, i stayed up all night trying to install an evo III 16g in my friends automatic 1998 eclipse. Unfortunately we ran into about 7,541 different problems. The current one has me stumped, maybe you guys can help me out. I pulled the wires to the spark plugs and injector plugs to make sure the new SS oil feed line was getting oil, but no matter how much i primed it it seemed to not want to flow. I even took it off at the oil filter housing and still recieved no oil during a prime. The oil in the car was changed right before this so i expected it might take longer. Any info on what i can do?
You mean cranking the car over to get oil to prime the line? Yeh, my car wouldn't send oil either. What I did was put some oil into the feed end of line and held it above the turbo and let it drain in to make sure that the turbo had some oil when I started it. then I hooked the line back up and started the car. Trust me, the line will get oil pressure (like the huge leak i got and still have :notgood: ). Regardless, that line won't see oil pressure until the engine is actually turned on. I sat there cranking on it for about a half hour, too. When I started it up, though, there was oil pressure. Only it kinda sucked for me because I found out that my "new" turbo was blown when I went on a test drive. Best of luck to you.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
  • For sale FIC 1220 Injectors AEM 320lph fuel pump with rewire kit
    FIC 1220 Injectors AEM 320lph fuel pump with rewire kit. 450 shipped to the lower 48 states.You...
    • elocneas
  • For sale 4G63 Bastard 20g
    Bastard 20g turbo Like New
    • arodgst
  • For sale 2g 97 GSX part out
    Ex-wife's project car part-out. Will be updating the list over the next few weeks and adding...
    • Type1DSMr
