Artago
- 2,094
- 31
- Nov 30, 2006
North Vancouver,
BC, Canada
A nice (picture oriented) summary would be great!
Thanks,
Tom
Thanks,
Tom
redlines hks 264s blue line Bc 272s
I got you. Heres my prediction from highest to lowest Kelford>>>HKS 272>>>>HKS264=BC272.
I think I just might look into a smim for the testing of the BC 280s and the delta Delta K272's. I need you guys input
Keltalon, thanks for your contributions.
I don't suppose i can talk you into testing the HKS 264/272 combo, is there?
I'll contribute $30 towards the dyno time.
Well the Bc out performed the the hks 264. Bc sent me a set of 280s to throw into the mix. So know I another set of cams to test before my car gets back to normal. I don't mind for I myself have always wondered about different cams and their impact on powerI think I just might look into a smim for the testing of the BC 280s and the delta kelford 272 grind. I need you guys input
So, the BC's and the HKS' were both installed straight up, no degreeing, right?
well the hks 264s was installed straight up the bc 272 was retarded on the intake about 5 degrees and the exhaust was advanced about 5 degrees. As far as actually degreeing the bc's I didn't but just played with different settings until I acheived a hp that I was comfortable with on the streets.
I will be getting to the dyno no later than wendsday to see what they will do
Like all large camshaft fuel setting at idle had to be adjusted. Stay tuned
I would have posted these sooner but I just got them in a email from the dyno lab. His network was down and could not send themredlines hks 264s blue line Bc 272s
Here is the 31psi run
One thing that is bothering me about the dyno comparisons and your logs. . .
The hks 264s are making 10whp less but with less timing and higher IAT. The airflow is HIGHER everywhere in the rpm range with the hks 264s at the same boost. 20 degrees different IAT and 1-2 more degrees of timing certainly makes up for the 10whp difference.
Thanks for helping me to make the correction!When you say your fuel settings at idle are you talking like the dead time and what have you by dailing in your LTFT and STFT? Just curious because I am about to install a set of these and to have somewhat of a base to know where to start is always good to know.
I forgot that you weren't tuned with the bc272s too.AHA! I see nowI forgot that you weren't tuned with the bc272s too.
. Thanks for ovservation thoughI will fine tune the cams that I will end up using. The dyno time is kicking me in the rear cost wise. and still have 3 more sets of cams to test. Thanks for ovservation though
Well I have installed the delta kelford 272. I am very impressed with the quality of these cam shafts. You can tell that they are a new grind and not a regrindVacuum is around 13hg. I have also played around with various cam settings and have decided to leave them as follows: Intake 0 and Exhaust 8 advance I will change them more once I hit the dyno. The car has a slight lope to it even with the exhaust cam advanced 8 degrees nontheless she pulls very hard up top. A little power is lost down low but makes it up on the top. It must me noted these are not small cams!! I repeat they are monsterous
Did you have to shim these? Are you buying these cams or are they providing them to you for cheap? I am torn right now between getting the Delta HKS 272 or the Delta Kelford 272. The HKS are 250 where as the Kelfords are 350 regrinded.
Not sure which to do. I guess itll come down to the dyno and what happens. Suggestions?
Do yourself a favor and get the HKS 272s, you aren't ready for Kelford 272s.. Do a search before you post up questions like that. The only similarities the Kelllys have to the HK$ versions is the number 272s. The Kellys are twice the size, require special valve train and sound like a tractor.
Please do not talk down to me, thank you. I know what Kelfords and have done the research. This question really wasnt directed to you. I will be running beehives.
So, could you OP please give opinion on the Kelfords for the street? I am kind of fed up with being in boost at 3 grand. Its killing my gas mileage. When does the kelfords really open up? Are they streetable? Do they hurt your performance that much more in the lower rpms compared to the HKS?
