OneFastEclipse
- 255
- 2
- Jun 20, 2002
Canton,
Ohio
Well, I got my new setup on the car yesterday. Put in a Bullseye VTRIM turbo rated at 48lbs, Dejon Tool Super SMIC, and UICP. We started at 5pm and didn't finally finish till 1am. Made a few trips to the store, stopped for dinner, etc. Anyways, the install went surprisingly smooth. No bolts broke, everything came off and went on smoothly. Intercooler fit just as Dejon said it would, like a glove. Turbo seated nicely, had to fab something up for the lower pipe to my intercooler but that wasn't too bad. We took it out and did a small tune on it, got the 02's to about .94 and was getting 21 degrees of timing advance at 7000rpm at 18psi. Car pulls very nicely, boost response is surprisingly extremely fast! I am getting 18psi no later than 3200rpm. Currently have the boost controller turned all the way down and have the wastegate set to open at 18psi. Holds boost, no creeping or spiking either. I plan to turn the boost to about 20psi with a nice tune. Right now I am stuck with a dinky ass intake (1 3/4" inlet) until my new one arrives in the mail. It is a HUGE bottle neck. Anyways, at 18psi it is a nice strong pull, much stronger than my 14b at the same boost. I had one question, being that the turbo is not watercooled, I had to do something with the lines. What I did was looped the lines back into themselves. I included a pic of this so you can see and let me know if it could have negative effects. Thanks guys.
Looped Waterlines
Turbo Getting Mounted
Dejon Tool SMIC
Looped Waterlines
Dejon Tool SMIC
