t04b(v-trim) Bolt on Discussion
Status
Not open for further replies.
Honestly bro, what is your purpose?? If you only intended to make others wonder what teh t04b is capable of, then you attained your goal. How about you go look for another thread to bash on and waste other people time. Every time i see a reply from this forum i think is something useful, but it's simply you, a no life again. If you were really sucha wiseman, such an experienced guy, why dont you try helping others diagnose problems or things like that. Can you please get a life, i don't think you realize that the only thing you're causing is making a bad name for yourself.
PS- Dont' even bother responding to me because im not going to argue with someone who has so much free time on their hands.
Although NOSLO2PT0 has been very helpful in other threads, I gotta agree with you man. It's getting the point where it's just annoying. Anyone with any ideas or progress is just not going to type because of NOSLO2PT0 being a jack ass. Someone control this kid...
If the Bullseye turbo does not perform it will go away.
Knocking others who are alsoDSM owners is disrespectful.
Actually kocking most people is disrespectful. This is a large group of people. Many more skilled than I. Some with more cash to spend. Some new to cars, especially modding. Old saying, "If you don't have anything good to say then don't say anything" Another, "If the shoe fits wear it" You know who you are!
questhe said:
This turbo came out a few months ago.
A few months ago? WTF You must be fairly new to DSM's. :)
Try about 4 years ago. :tease:
Your run is pretty good imho, especially if it was on pump gas. About 3 years ago i ran 12.98 @ 106 in a full weight car(minus spare tire), on a 14b, 450's, starion FMIC, hacked 1g maf, stock non-eprom ecu, and no other fuel control or engine management. I did run racegas though. :)
Why, yes I am. thank you. :)
Thanks for the complement on my run. ;)
Checking on the 1/4 mile times, 11.9 is the fastest for a 14b.
Assuming full weight - say 3200 Lbs, that engine was making 456 HP.
http://www.stealth316.com/2-calc-hp-et-mph.htm
Your 12.98 was 359 HP. Good job. I guess on race gas you don't have to worry too much about leaning out with thse 450s.
According to this
http://www.rceng.com/technical.htm
you should have burnt up.
I don't see any times for a T04B or V-trim. I hope that no one went faster than 13.5 'cause that means I am the fastest V-trim DSM :rocks: :sneaky:
So, my goal of ~400 HP on my car (3140) will get me a 12.46.
I did run on pump, BTW, and that is the way I'm keeping it.
Man who cares about the damn 14b record, where the hell are the Mods here when you need them.
According to this
What are you trying to say, that i'm lying? Also, since obviously you don't know, trap speed is a better indication of hp than ET when using those calculators.
Don't you wonder why that is? It sure as hell isn't because the turbo's only been around for a few months, thats for sure. :)
What will I have to run to get the doubters to change their minds?
Will they change their minds with any timeslip?
Or is this just a waste of time?
damn good question. what would make you guys happy? low 12's, 11's? what would be an acceptable time and or hp level?
I would say that since its supposed to be an EVOIII or 20g replacement, mid to low 12's on pump & 11's on race, would be nice
i just recieved my v-trim today once i unpackaged it i was happy to see the size difference between my fpbigt-28 :thumb: . on the other hand i ordered the kit and i recieved it with no oil drain line :notgood:
OK, there may be some misunderstanding here :p
- I am running on gas out of a pump.
- The numbers I run at the track are the same ones I can run on the street - every day.
- I am impressed with what the people with the 14b have accomplished.
Those are seroiusly great achievements.
I am talking about squeezing every last drop out of that turbo,
and a driving skill that I could not match.
OK, now my thought is "what if we gave leon reitman the t04b?" Wonder what he could do with it? 10s or better I bet.
Another problem is that this is probably more turbo that most people need. A lot of people are going to be blowing up their cars with this. Some of those will blame it on the turbo.
That is a big reason to recommend the 14b and 16g to the crowd that has to ask 'what turbo should I upgrade to?"
The snow on the ground is there from Christ for us. I agree with Paul. Give it some time. I am a big fan of the Bullseye turbine. This is based on the look and feel of it, no flow test. I had one on my RS49 andh before I purchased my 60-1 I made sure it came with the SAME housing. I got the car out on a day without snow and boost/lag was not a problem considering no tune and a short ride. Seems like all of the complaining is being made by guys who do not have the Bullseye. Mark
This turbo seems to be designed for larger displacement engines run at a lower boost level, as indicated by the information in the quoted post 10," The wheel is theoretically good for moving alot of air at relatively low pressures." The problem with this is, to continue to make more power on a lower compression small displacement engine like a stock 4g63, you have to continue to raise boost pressure. Honda's typically run higher compression, so they often keep the boost low around 15 psi. The turbo may not be able perform how you want it to if the amount of boost you can run is limited by compressor surge. My friend ran into this problem with his TO4E 60trim(not 60-1), which has an inducer very close to the same size as the v-trim. When he tried to run ~25+ psi it would surge like a bi***, so he had to get rid of it.
I'm just trying to look out for other DSMer's, especially those that are fairly new to DSM's, to try to make sure they recieve accurate information and prevent them from being mislead. You have to be careful when it comes to vendors, as their #1 priority is making money, or making a living for themself.
I personally think nazthug's 298whp on piss-91octane, stock longblock, stock cams, and 550's at 18psi of boost is pretty good, wouldn't you? Especially with this new/old ( ROFL ) turbo everyone wants to get into detail for for whatever reason. With proper cams, better octane, higher boost, decent tunning, I can see this "small" turbo getting its quoted hp mark easily (350-400), especially with more and more people buying them. I think it's a step in the right direction.
Sure people can buy a Green or 50trim that will produce the similar numbers FOR SURE since those are tried-&-true...but 14b turbos have outdone themselves and getting equal quartermile times. Does that mean everyone should stick with their stock turbos? I personally don't think so. David is just offering an alternative to turbos that are already out there. Why is this a bad thing? Even if he does or doesn't have the 'bad' history people mention that he has, what vendor doesn't? There's alot of people that hate vendors that I consider top-notch, for whatever reason. And I think David 'so far' has been doing a good job of service, correcting errors, answering questions, now offering a warranty, and staying on a professional level with all the lurkers and finger-pointers.
I find it funny how all the TO4B turbo threads started tend to get locked. If you look at all the locked threads, you can kind of see a pattern as to why, towards the end...I can understand where NOSLO2PT0 is coming from though. It would have been nice if a test car produced actual numbers for us to look at and 'believe'. But I think that whole ordeal was already delt with an answered. I don't think its going to get anywhere by reiterating it over and over again...other then wasting space and your finger muscles. Soo...I say we just wait and see all the numbers start to roll in. If they are a cheap product or if David really is a scam-artist...then again, we'll all find out. Lets stop the assumptions and get back to what we all want..."Just the facts, ma'am".
all this talk about 14b records is a joke to me, cause i dont give a shit, who cares? That turbo has been tweaked, worked and abused for like 14 years, ofcourse someone somewhere is gonna sqeeze something crazy out of it, i dont even give a shit
ill tell you this, i ran against guys with 14b's, 16g's, t28's and 20g's and i pulled on ever single one of them, now that im on 750s, 21psi and water injection, im plenty happy
so keep your records to yourself, im not here to impress anyone or break any records, i simply wanted a decent turbo that fits my needs and so far this one has, thats the end of the story
the car is making much better power now than my previous 298whp dyno...give me some time to pul out some dynos :sneaky:
I've seen guys with 20G's that run 15's. Just because they have a bigger turbo doesn't mean anything. But, as long as you are winning, thats what matters.
What were/are your goals anyway? And we are anxiously awaiting more results from more T04B owners.
this is getting old. mutt this, t04b that. I can honestly say that I hope this thread gets closed because instead of discussing the turbo(t04b) all you guys talk about is the credibility and how shitty or not not shitty these turbos perform. there aren't any numbers to back up anything so we are all up in the air as far as our perception on how these turbos perform. I would rather see this thread stay a "discussion", but if it stays out of hand then mods, please close this and someone start a "bullseye t04b turbo review" thread so people with actual experience with the turbo can post their results.
IF the turbo performs like shit, isn't that discussing it?? I thought turbo performance was what the topic of this thread should be about. What would you like us to talk about? :confused:
I think the discussion should be for people who own this turbo or are thinking about owning this turbo. If you do not fall under this catergories then just keep your mouths shut. If you want to tell people something that you feel is important just PM them.
Status
