420A Bleeding the master cylinder
Keola916
44
Mar 16, 2022
Sacramento, California
I'm about to replace my master cylinder because the seal that goes through the firewall leaks a lil. I know how to put it in I just need a little guidance on how to bleed it after replacing it. A step by step or video would be very helpful
-thanks
First you need to bench bleed the master cylinder. This video is not dsm specific obviously but it should give you an idea.
Then you just need to bleed your brakes like regular. You either need a friend or a vacuum pump.
I do both then manually squirt the last 2 on every line to be sure.
Is It ok if I just bench bleed it and then install it or will I have to bleed it again after installing it?
Bench bleed it, install it, then bleed all four calipers
Or since it's an N/T he'll probably be bleeding the wheel cylinders on the rear, but everything still applies.
Also I wasn't sure at first if O.P was asking about the brake master cylinder or the clutch master cylinder.
OP - Just pouring brake fluid into the master cyl won't purge the air that is trapped inside the plunger/piston portion (the business part of the master cyl). If all you do is install, pour, and go you'll spend a lot of time working that trapped air out through the system. Bench bleeding saves you time, effort, and mess.
Upon installing the master you're still going to get air in the top side of the lines even though you bench bled the master cyl. Because of this bleeding the system is a must to purge the system of air. For the clutch it should be pretty quick as the length of the clutch lines is short, but it is still necessary.
