clutch master cylinder
gsx4357
103
Sep 26, 2010
maricopa, Arizona
hey guys i need help again and i need it quick. i just replaced my clutch master cylinder because it was leaking. i bled the lines like 3 times and i adjusted the master cylinder correctly and i did everything by the book...problem is when the car is on it wont go into gear but as soon as i push in the slave cylinder it will go into gear and everything is fine...i had the car on and i put it in first gear and i forgot the car was in gear after a minute and let go and the car stumbled forward and dies...naturally...but then i turned the car back on and it wont go into gear anymore. then i repeat by pushing in the slave cylinder and turn the car on and the car now goes into gear...could it be my slave cylinder going out or is it something else that im not thinking of?
thanks in advance
ok thanks guys im going to get right on it
yeah so i changed the slave and bled it though again and bled the master again and i took it for a drive and it worked fine...then i started the car after 5 minutes again and it wont go into gear again...does anyone think maybe i got a bad part or could it be something else?
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
