Clutch Master Cylinder
corsair231
81
Oct 7, 2007
Peachland, North Carolina
Hey guys. Still searching on my release problems. I was looking at Clutch m/c's for my 90 Laser T. They show two. One for cars with cruise, one for without cruise. Neither was in stock but looking at the illustrations the only difference I could see was the reservoir size. The bore size was the same. What's the real difference and are they interchangable?
Thanks
Thanks. The illustration only showed one side and it wasn't the side with a switch. Seems like they would show the important stuff but, WTF.
The one for Cruise just has a Switch built in to kick out the Cruise Control - You should be able to use either one & just not use the Connector.
What switch are you referring to? Because as far I see there is no switch.
Cruise Control is the first picture and Non Cruise Control is the second picture.
OMG...I'm confused again. The 04 is the cruise one right? That looks like the one that is on my car. The 05 (tall resevoir)looks like the one the illustration said was the cruise one which is what made me wonder in the first place.
Now, back to the original question.... What's the difference???:)
Cruise switch is on pedal assembly not master cylinder. I think it is a packaging thing is all. either will work.
DJ
