AWD 4G63T 800awhp in CRX
Status
Not open for further replies.
CrazyGSX
168
5
Feb 13, 2004
Waterford, ON, Canada
i talked to matt from magnus motorsports and he priced me $30,000.00 labour/fab for the build of the CRX
they charge 100$ / hour so its about mouth and a half of work. matt tolled me its a ruff estaminet but it still
scares me that they would have the car that long when the should have it for 2 weeks for the fab/labour work.
2 sub frames and rear trailing arms and front A arms with moded shock mounts and battery box flush mount in the trunk. mount the trans and engine and rear diff, with custom ordered axles and driveshaft, use gsx hubs and custom knuckles and wire it up to ems and dash. done i have tons of parts to buy for it to work and I'm thinking 30,000.00 is too much, and i think he may of made a mistake.
here is the parts list, it has more then what magnus will have to do, they don't do body work or paint and no car audio. i will be using champion motors for body and panit and wild car audio for you know LOL
1G 2.0L 4g63t DSM Crate Engine with HKS 280 Cams,unorthodox racing ULTRA T cam gears, YELLOW TITANIUM NITRIDE super tech valves +1mm, super tech dual valve springs, 9.1 comp magnus/ross pistons, magnus aluminum con-rods, magnus billet crank shaft, Black Cast v3 intake manifold with secondary fuel injectors and rail. T4 PT 6766 2gen turbo ball bearing center, ported comp, polished comp housing, v-band tur out. Ram horn ex manifold, Polished neo cobalt color FLF valve cover with 10AN vents. Wilson Throttle Body 75mm TB, Kiggy a/t kit, unorthodox pulley kit, ATI Super Damper, polished 44mm Tial waste gate, 16AN cooling neck and return, blue Gates timing belt. Balance shaft delete, Mishi Moto thermostat 68C, HKS spark plugs, FLF front engine housing BB oil pump. kiggy 12-Tooth 4g63 Crank Trigger Sensor.
HKS f-con v pro 4.0 and flash editor, mix dial. Custom engine wiring harness
Spark tech Coil on plug and with M&W CDI SEQUENTIAL set up. black coil holder.
Neo cobalt color 3” intercooler piping 2mm aluminum wall, viberant intercooler 33"W x 12"H x 3.5" Thick 3” inlet/outlet, 4” neo cobalt color intake pipe 2mm wall aluminum. Puple HKS pipe cupilers, K&N air filter, ½ rad. 2 over flow cans,3 12” Spal fan, B&M trans and engine oil coolers with fans, Polished Tial BOV 50mm Q
2 Fuel cells 6gal meth and 12 gal 91oct. 2 Fuelab 1000hp in tank pumps, magnus fuel rags. And filters. 2 Auto meter sending units 240-33 OHMS
Built Dsm 2G automatic AWD transmission with front LSD and welded center diff, high stall 9.5” TC, shift box lite tranny controller. 300m t-case with magus bearing cap 950hp. 4 bolt Built EVO 3 LSD maxlock rear a/t gsx gears , custom DSS 300m drive shaft and axles 950hp.
Koni 2812 mk2 struts and custom Eibach springs, custom sub frames and custom upper control arms, CRX 1988 Function7 Engineering lower control arms, custom trailing arms and knuchals, custom A arms, gsx hubs, Ksport 8 piston brakes neoTitanium color calipers f/r 2 sets of front brake kits 356 X 32 rotors.
Soiled mounts for engine, transmission, rear diff and suspension
Two Universal Stainless Hi-Power Ti Mufflers 75mm inlet 170mm body 120mm tip , viberant 4" Catalytic Converter, 204 ss exhaust pipe 4” and 3”, 44mm pipe for WG, WG rerouted back into exhaust pipe
sparco Chrono Road seats black on black and P310 steering wheel, sure grip hand controls
ten color white face glow shift gauges; Boost/Vacuum,transmission temperature gauge,Water Temperature Gauge, 3 3/4 In Dash Tachometer w Shift Light blue, Oil Temperature Gauge,1500 F Pyrometer EGT Gauge, Oil Pressure Gauge, Volt Gauge,2Fuel Level Gauge 240-33 OHMS, 3 3/4" In Dash Speedometer Gauge, White 7 Color Dual Intake Temperature Gauge, White 7 Series Digital Wideband Air/Fuel Gauge, and 3 pod A pillar
sparco kill switch, 11 led blue toggle switches with blue safety covers,
4 blue single led for high beam and starter panel, 2 green single led for turning signals, blue starter button.
chrome dub rio 5 18”x 8” rims
nitto high performance, all-season NeoGen HP 215/35R18
Honda CRX Cyber PRO 2 Full body Kit
F1 fenders
Bodykit.com headlights and clear corners
stap bumper lights
ZDMK Speed black housing tail lights
Duraflex Spyder Hood Scoop dual ram air
Hi-Rise Style Spoiler with LED - 01-HOCR88SL
E3iO Car pc full loaded, blu-ray player
Alpine PXA_H800
Alpine RUX-C800
Two Orion HCCA 15” SPL Subwoofers 4ohm
HCCA 11000.1D amp
HCCA 3000.4 amp
XTR 1200.4 amp
XTR 600.2 amp
2 morel ELATE TI 903 ELATE TITANIUM 3 way COMPONENTS
morel 3 way ELATE TI 503
4 morel ULTIMO TI 802 8” subwoofers 2 ohm
4 CH home made stereo to mono/stereo converter for 4 CH bass amp and 8” subwoofers.
2 XS Power XS30K batteries
320 amp DC power alt
Showtime STCA 2/0 00 AWG Gauge blue power wire
wirez speaker 14 gauge wire for components
wirez speaker 12 gauge wire for 8s
shy high audio 8 gauge sub wire for 15s
jdm power mirrors
Electric Life custom fit power window kit HD31-K
2 tool maker 1/0 to 2/0 amp input
Power door locks
4 Tool maker 1/0 to dual 2/0 amp input
Tool Maker buzz bars 2/0 gauge
Spal power window switches Part # 33040147
Stock Honda parts; brake and gas petal assembly for auto trans
Door panels for EF8/9 with power windows option, SIR inner door levers,
CRX SIR EDM switch pods, Integra center console
Mitsubishi stock parts, GSX A/T TCU, shifter lever assembly and Trans cables and TCU wiring harness, GSX 2g steering pump.
Why?
I understand the cross platform swap when people who will actually do the work do it because the want to, and can. But to pay all labor out of pocket the amount it will take to get this done, only to have a car you could sell for $8,000 is a bad idea.
It's like paying someone to sleep with your wife, and being proud of the kid.
LOL a crx is like 1500$ for a mint one black book price
I like the Colt with a 4G63T and AWD idea. For a little different look, you could go with a Mitsubishi Cyborg swap. It would be a LOT less fabrication. The things I could do with your budget.......................
there no value diffusions in a colt and crx its like the same thing. and people will still talk bad about me.
give the lil honda a chains
for 800awhp it take just as much fab
i would like to use this thread for the evolution of this project and ill be posting pics and writhing may thoughts
this is for the honda lovers, say no to v-tec and bring out the dsmer , 4g63t rule
oneslowwdsm don't make mess of my thread. if you don't like it move on.
i have a pic here of what the fuel cell will or may look like, is pic is a ef swap civic wagon parts
my AWD mirage coupe is for sale. dont know if you need account to see ad? from experience building one and seeing locals "try" to duplicate the effort, you would be crazy to build something like this from scratch. when you build something like this with so much custom work you have to expect all sorts of unseen problems. if magnus quotes 30k and one month labor , expect 45k and six months without your car. local here spent 45k building AWD A/T civic to "beat" my amazing AWD mirage. after an agonizing 45K and year of teeething problems, his car was no where near close to even challenging the yellow car. he parted it out and got 18k back. my car is a 10 year effort with all the unforseen problems worked through. its an amazingly fast car. and an absolute steel for someone who is serious about owning such a car. it would be much cheaper, faster, less headache to buy my car and make the changes to it to suit your goals. but before you make any changes you might just want to drive car first the way I had it set-up. I assure you it has the most amazing power and response available form an AWD 4g63 platform.
http://www.4g61t.org/forum/viewtopic.php?f=66&t=40373&p=321266#p321266
Total waste of money! ! Unless you just have the funds to throw away. Listen to all the guys here man!! 45k you are about only another 10k from buying a nice used early 2k Porsche 911 turbo which will also come awd and have much better value! 30k can also be a down-payment on the new turbocharged civic that's coming out.
Honda does have an old awd wagon you can find perhaps you can find one and take the awd system from that.
Sigh. Not this shit again. Either build the Honda motor or stick with a car that already has a 4G63T in it if Magnus' $30k price is too rich for your blood. $30k to plop down all at once for anything, well must be nice. Or your taking a hefty loan out. Fabrication isn't cheap regardless.
Man I have about 13 grand in my car and I'm overwhelmed. If I had 30-45k I would smother myself with a pillow.
Be realistic
Step back
Think
theres no one resale value in performance cars. You will barely make back what you paid in labor. Had I of known this I would have just waited for someone else's complete project and life would be easier. Everyone has the right to dream and everyone has the right to tell you you're crazy. Do what you want. Don't talk about it be about it.
get yourself a welder and get to work.
crx isnt that light or i would have done it myself
I already told you from the previous thread that was locked that your bill was going to be like this. If you can't do it yourself, then you are paying a professional for their services.
This guy is trolling hard. The mod list is well over $30k by itself and some of the parts he has on there arent even available....
I'm not sure why you would want to spend this much money on a honda when you could stick with an oe 4g car for 1/16 of the price that could scream in whatever event you would like.
Oh god, not this sht again. The last thread was locked/deleted after OP thought we were calling him idiots because of his race/color, it's obvious he's a troll. Can we just ban this clown already?
Status
