- Ownership Status
- Currently Own
- Vehicle
- 1990 Mitsubishi Galant GSX
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- CMPE 3in turbo back with cat
Evo 8 mas
ETS intercooler
Walbro 255 fuel pump
FIC 1150cc injectors
Awaiting install FP DSM 68hta and ETS intake pipe
Recently bought IR solenoid , walbro 450
- Mods-Engine
- 1991 4g63t out of a Galant vr4
Awaiting install 6 bolt block with wiseco 1400 hd 0.020 pistons, eagle rods, acl tri-metal bearings (rod and mains), polished stock crank, ARP L19, OEM timing and gasket kits
Cylinder head has SS valves, BC springs, BC 272 cams, AEM cam gears
Recently bought a bare 4g61 head that I'll rebuild with ss valves, bronze guides, kiggy hla, revised lifters. Still looking for springs and retainers I'd like.
- Mods-EMS & Logging
- Ecmlink v3
Innovate auto timer
Awaiting install of SD and e85 with flex fuel sensor
- Mods-Drivetrain
- Stock for now
JNZ short shifter
Awaiting install TRE stage 2 transmission with 4 spider, TMZ rebuilt transfer case, TRE rebuilt 4 bolt rear diff, Act sprung 6 puck with streetlite flywheel, new rear axles, new oem shifter cables,
- Mods-Handling
- BC coilovers
Moog balljoints and tie rod ends
Energy suspension bushing all around
Evo 9 bbs wheels
Whiteline rear 26mm sway bar
Swapped in 3kgt 1g calipers with slotted rotors
8g brake master cylinder
eBay front strut bar
Awaiting install Jay's racing rear toe eliminator, bulfab moustache bar, true street fab 3 piece crossmember and rear subframe rebuild
- Parts Wishlist
- I want a Act pressure plate, rebuild driveshaft, body work and paint, windshield wiper linkage and wiper arms, and a professional tune
- Background
- My buddy gave me the GGSX, with the understanding that he gets first dibs if I ever sell it.
