3000gt4g63t
- 1
- Dec 7, 2016
Jacksonville,
North Carolina
Okay. I've got a good one. Only one other person has done it, and he did it to a vr4. I'm swapping a 4g63t into 3000gt fwd sl and in trying to beat the fwd record for 3s. The best part is the pinout is SUPER SIMILAR, and the vr4 harness will plug directly into a 2g dsm ecu. Thats beside the point. I'm picking up my block in 2 weeks then its going to the machine shop. I've got wiseco 8.8:1 pistons and eagle h beam rods going into a 7 bolt. I don't know too much about the 4g63 but I have a really good general knowledge of all motors and this isnt my first time. The 3kgt is completly gutted for full weight reduction but its still a heavy car! I'm looking for around 700 to the wheels on 93Oct (e85 is 50 minutes away!!). Best way to achieve that in a relatively heavy car?
So far I've got the pistons, rods and I'm going with a forged crankshaft and possibly a aftermarket cam (suggestions on cams please).
Suggestions on turbo?
Any advice towards my build is greatly appreciated. I know this post is super scattered, and I do apologize. But its 3am and I just finished working 12 hours. If I get enough people interested I can document my full build and do a complete write-up.
! Then dropping it off at the machine shop to get it checked out. I figured for $50 its worth the risk, if its bad I'll scrap it and buy a long block. Still debating between BC cams or Kelford 272s. Heard good thing about both, and the BCs are a little on the cheaper side. Getting a stock crank balanced and polished (that saves me a lot of money). Not sure if I will get the head ported. Heard the 7bolt head has super good flow already, but time will tell. Anyways I'm just rambling because on really excited to be building another engine. Never gets old!
. E-85 is definitely my option, and currently going for 600hp. That sounds more realistic. I just picked up a block that I found cheap in the area and I'll be dropping it off at the machine shop so I can begin this adventure. Also, I'm not going to use the 8.8:1 pistons, picking up some HD 10:1 pistons instead, for obvious reasons.
