- Ownership Status
- Currently Own
- Vehicle
- 1993 Eagle Summit
- Turbo Type
- 16g
- Drivetrain
- AWD
- Transmission Type
- Automatic
- Build Type
- Street
- Mods-Bolt-on
- Cooling:
-Koyo Evo III aluminum race radiator
-Koyo 1.3 bar radiator cap
-JDM RVR pusher fan
Fuel:
-Evo IX 560 cc fuel injectors
-Rewired Walbro 190lph fuel pump
Intake:
-Evo III intake manifold/throttle body
-JDM RVR intake piping
-JDM RVR top-mount intercooler
-Open element filter
-Evo IX OEM bypass valve
Exhaust/Turbo:
-Evo III 16g (OE internal wastegate)
-Evo III exhaust manifold/o2 housing
-3" o2 housing back exhaust
Exterior:
-JDM RVR side markers
-JDM RVR center garnish
-Expo Headlight swap
-hood scoop
Interior:
-JDM RVR cluster swap
-3g Eclipse steering wheel
- Mods-Engine
- -7-bolt EVOIII 4g63t
-Kiggly HLA
-baffled oil pan
-External oil cooler
-Fluidampr
- Mods-EMS & Logging
- -95' E-prom ECU w/ECMLink V3 full
-PLX SM wideband AFR (LSU4.9)
-PLX SM Boost/Vac
- Mods-Drivetrain
- Trans:
-JDM RVR auto trans cooler
-JDM RVR TCU
-Forced Four Shift Box w/ TCU package
- Mods-Handling
- -05/06 Outlander front brake setup
-Rear converted disks
-Hawk HP+ pads (F+R)
-5-lug swap
-1g AGX front struts
-2g Koni yellow Rear struts
-RSR RVR lowering springs
