92 Galant
Will be changing the springs in like 2 hours or so, and will test it out after that. Assuming you want the log to see the settings for catching idle. Biggest concern at the moment is being able to control boost.
When I try to open the log where I made a pull, it errors out and won't open that one, but here is one where it dies.
Any tricks for getting the oil pan off? Have all bolts out and it still won’t pop off.
looks like there was a ton of gasket sealer on it. I’ve taken a small flat head and beat it in between the pan and block a few spots arojnd the edges, no luck. Tried pulling as hard as I can and all I did was move myself, this thing is on…
Going to be measuring some more when I get home, but this looks like it will fit with a little modification.
