Imback
Freelancer
- 1,423
- 546
- Nov 8, 2006
Long island,
New York
This is the Build Thread for 92 Galant VR4. Reply below.
. Long story short that car ended up being my current 92. I was ecstatic when he sent the info and photos but i knew it was going to be a big project to get it to be road worthy again. I grabbed my friends trailer and headed out of state to pick it up. It had been sitting for 12 years and typical of these cars the rear calipers were completely seized up and this guys yard was at a downward slope so just getting this thing on the trailer was a mission in itself. That semi trailer truck was his personal toy hauler and that's what we had to use to pull it out of his yard. Thats a saturday i will never forget
. I asked a few friends if they had a serial to usb adapter. I remember in my early 20's being able to buy a new keyspan adapter from the store but those days are long gone haha. I was fortunate that i had a friend that actually did have one laying around. I wired in my aem 5 bar and connected to the ecu did my changes and got the car to start
. There was so much going on so i just figured it would be easier to just start from the cabin and work my way to the engine bay. I took out the steering Column and went to work. I removed so much ghetto wiring that was t'd into main relays and found cut wires it was a mess. Going through the wiring took me about 3 weeks on and off when i had the time. Finally had it looking normal and put the interior back together and threw my old wheel set up out of my old galant.
. Sure enough the brakes line were rotted and let go. So i put everything back together and decided to call it quits for the day and needed to figure out what my next course of action would be. I was talking to josh from jnz and he mentioned he had the same issue with his current galant as well and he had braided lines made to replace his rotted out lines. I said that's perfect and asked if he would be able to make me a set. He said yes and i also ordered the abs delete kit with a new non abs proportioning valve. It arrived a few days later and now i just had to wait for a semi warmish day since it was now winter. Finally got a break the following weekend and went to work removing all the old lines and abs system. I ran all the lines the kit was perfect. Earlier in the week i printed up some new brake line holders for the larger lines and they came out perfect.. I called it a night after installing the holders. Came back the following day and buttoned up a few things and bleed the system and now i have brakes
. I cleaned out everything as best as i could. Now i had to tackle and wires that were chewed on as well as shitty wiring from either the previous owner or whoever he let touch the car. I had some new connectors laying around from a old wiring job a did a few months back and went to work. I was able to get most of the connectors replaced except for the connector that go to the coolant temp sensor and a 3 other misc ones. i took out the leaking stock radiator and threw in my afco radiator to help clean up the bay. After getting that sorted out i replaced the entire timing system and swapped in another valve cover i had laying around since i despise chrome. The exhaust was a hack job from the o2 housing they made to the downpipe that connected to the remaining exhaust via a sanitary clamp. But that wasn't stopping me from driving the car so it was put on my next todo list.
. Decided i should finally wash the car and it cleaned up nice.
So my next thing to tackle were the lights. They had hard wired in an old school hid system with the ballast box the size of a brick and the corner lights didn't work. Thankfully my old galant hadn't gone to the scrap yard yet so i was able to salvage the stock connectors and and wire them into my 92. I threw in a set of led's then tackled the corner lights. I have jdm clears which is a single bulb light. The correct way to use these would be to get the correct pigtails and lights and wire them in. The po just shoved the huge usdm corner bulb into the housing and forced it in. The bulb literally melted the amber housing and on the other light it melted onto the bulb so needless to say it cracked the amber housing. So i took and pick and removed the remaining burnt plastic on both. I wanted to still have a amber corner light at night so i decided i would use a amber led. I spent some time taking measurements of the housing inlet and 2 hours later i found a pigtail that would fit the housing and excepted the led i was trying to use. It was perfect even had a 3rd wire whenever i'm ready to tie it into the signal harness so i could get the corner light to work with my signals. The leds blew my expectation away and look really nice at night. I redid all the lights for the brakes and turn signals in the rear to led to give it a nicer look. If you ever thrown leds into a older car you know your going to get hyper flash i found a relay that fixes the issue by changing the resistance.
Hey sorry but the wheels sold a while back. What part of ny you from?Love seeing these cars pop up. Like you I hated them when I was younger but they’ve grown so much on me.
Would you sell the old wheels? I like the look of them. I’m in NY too.
so after removing this abomination of a drain line a made a new return with -10 and called it a day. The car didn't smoke but you still smelled exhaust cause of the rotted out o2 housing and exhaust. I started to order material so hopefully by spring i could make a new o2 housing and complete exhaust out of 304ss. V bands were out of stock at the time so i was playing the waiting game but it didn't matter since my list of other things to do to the car was still huge so onto the next issue
Unfortunately most clean cars go to shit when they switch ownerUgh.
This is such a mind-$^%&.
Makes me want to cry, and warms my heart at the same time. As I've said, I'm happy it's still alive and in the hands of someone who is bringing it back.
I can attest that NONE of that work pictured was done by me, with (maybe) exception of the battery grounding that I did back around 1996.
That car left my possession being a clean, 14B car that consistently ran 13.0s@103-104 @21-22psi, with just a used Centerforce clutch, 2.5 downpipe/testpipe, 190 Walbro, hand porting of the exhaust components, O2 dump and an original Hallman boost controller.
It was my first Mitsu and what got me into this mess.
. I don't know how deep i'll go into restoring the car but the overall goal is to have a car i can drive cross country without having to think twice if it will make it. I wanted to have it done this summer but that was a far fetched idea
. I didn't take any pics of the front assembly's but this is not a new thing. It rode worlds better. I'll eventually switch to feals at a later time but right now i have other things i need to take care of. Next thing to address the fuel system. I took out the old pte 880's i think. I threw in my hi z 1600's removed the resistor pack. Replaced the factory fuel filter and the car was worlds smother. I switched the car over to e85 and then noticed the fuel hose is leaking
. Well now i had something else to fix
. I decided i was going to take a little break and just drive the car until this tank was empty and then address that and look inside the fuel tank.
. It fought me on removal of everything including the manifold to turbo bolts which i have never had a issue with on all my cars i've owned up to this point. I broke the very first bolt i tried removing on the o2 housing i figured it would be easier to just remove the hotside and take it to work so i tried the exhaust to manifold bolts first one stripped on me as well. At that point i had enough and my milwaukee 1/2" came out and 3 out of 4 were stripped. I got the hotside off eventually and the o2 housing bolts got the same treatment from my impact
. I removed what was left of the exhaust which actually broke at the flex section and fell off when i yanked on it a little. At this point i knew i was going to have to helicoil the stripped threads but on the o2 housing side they were in decent shape besides the broken bolt. I did have to remove the broken bolt though and even that fought me. I tried welding a nut onto the face side of the housing to get the broken bolt out with no avail. I ended up having enough thread protruding through on the other side that i was able to get a nut semi on there and welded it on. That did the trick but it was slow and even cherry red did not want to give up without a fight. Now that the bolt has been taking care of i was just waiting on on one last package to start making my new o2 housing. In the meantime i brought the hotside to a machine shop by my job to have them deal with drilling and and taping for the helicoils.
. In hindsight i should drove my vr4 to work and left it there since it's not my daily. I don't have pics of the downpipe but as you can see i have a transition from 2.5 to 3". I had a turn down for a little bit until i could coordinate sometime with my friend to use his lift.ThanksNice work man!
That and a bunch of other things but i only have so much time. These are older photos the engine bay is a bit cleaner now.That engine bay needs a good power wash.
