2G 4G63 Timing mark (crank)
DiamondStar90
209
5
Oct 9, 2010
Waco, Texas
Hey guys i was wondering if somebody can point out where the crankshaft timing mark is ..I see the indention on the crankshaft position plate but i don't see where its suppose to line up to?? if possible please post a picture and im working on a 98/99 4g63 motor
Thanks
ill see if i can take a picture in awhile to show you what i have
The notch below the bolt that is up and left of the crank:
Matches up with the notch that's outlined in blue on the trigger plate:
And this is a '99 motor, for reference.
There is a matching arrow cast into the front cover at approximately 2:00.
Look at figure 17 at Timing Belt VFAQ
i hope the photo uploaded but anyone see it?
Hey are you talking about this?
Is that where its suppose to line up??
the other guy said its at 2'o clock :confused::confused::confused:
Yes, that is the bolt/marking I'm referring to. The dowel in the crank sprocket will be at 3 o'clock, which would make the notch in the trigger plate line up with that marking.
No idea why that image is used in the 2g article, as that's a 6 bolt alignment mark. See the image and thread below.
http://www.dsmtuners.com/forums/art...l-installing-timing-timing-belt-6bolt-2g.html
Yeah i know right? ..everyone around has 1g's and look at me like an idiot cause i'm like well there is no mark at 2'o clock lie theirs ....ill line it up and take another picture and see if you think its correct
Ok sorry. For a 7 bolt it is going to be to the left and above the crank. Like 10 or 11 O'clock. Totally missed the 98/99 motor part. Any ways the picture that snow boarder posted is correct. See the top most left bolt has that little tab (timing mark) coming off of it matches up with notch on the sprocket plate. Make sure the cams up top are on there marks as well as the oil pump. Make sure they all line up on top dead centre of cylinder one.
I'm working on my 7-bolt 4g63. I added an ATI super damper. Between that and the belt, this is as close to my (by eye) TDC mark. Besides my pencil mark, does this fly based on the timing marks? The cams and oil pump sprocket are all perfect.
Maybe its camera angle but it doesnt look right to me. Everything is relative to crank. You set crank dead on THEN look at everything else.
I pulled a random image online. This is dead on. You can draw an imaginary line from crank center through the notch and it will hit the point of the mark.
Thanks for the reply. This has been racking my brain all day. This is as close as I can get. If I go over another tooth on the belt it greatly overshoot the notch when the tensioner is tightened to spec.
Here's a real pic of my 99 Eclipse GST crank and cam timing notch marks:
You are checking the timing marks improperly. The cam gear's timing marks position are the ones you have to check, not the crank mark. Because the crank timing mark must always be aligned at TDC when we talk about the valve timing.
According to the pic, most likely a tooth off at cam gear or the belt still has a slack. But there is no way to be sure with only that pic, align the crank timing marks and put the tension on the belt, and take a pic of cam gear's timing marks from center/straight, and then upload it. Then we can check. P.S. Don't force the cam gear timing marks to align when you take a pic, just leave it as is.
This is what I got. Looking at the exhaust cam gear. Even though the tool aligns, the dowel looks a little off to the left. What do you guys think?
It looks like you've got slack in the belt. If the pulley is already tensioned my suggestion is to pull the pin, pull the tool rotate the crank twice and look again. It appears you don't have balance shafts so you don't need to worry about oil pump. If you had balance shafts you would need to rotate crank six times before all marks lined up again. Once crank is DEAD ON, then you can check cam marks. No tool, no nothing. I don't even look at them to make sure I'm not influencing anything. Line the crank up all by itself, then check mark and check tensioner. If either are wrong fix it. Post pics. I will bet money you are ok on cams but your tension will be wrong. The slack i'm seeing is slight and in between cams. It's juuuuust enough to probably put the crank back on point but when it does you'll put the slack on the tension side (where it should be) and you tensioner will no longer be right. Easy fix without removing the belt. Try it and see. Should take you all of 5 min.
Ok. So, I pulled the pin and rotated twice. The cams were good, but the crank was still off, as was the hydraulic tensioner. To make the pin slide in and out of the tensioner hole, the pulley holes are sitting at about the 3 and 11ish. I verified TDC against the pencil mark I put on the trigger plate. It's off by a smidge to the right, and I see nowhere else that there can be slack. Verified the belt size against the ATI hub, and the belt notches fit and stay aligned between the oil pump and the hub. I don't think degreeing the Cams is involved because they're still set up at zero from the old setup.
No. Line the crank up. This is the most important part. Everything else happens after that. Line it up to the factory mark. There simply is no other way.
I don't know what your car is (I guess EVO 4+) and I almost missed it with my smartphone small screen, but now I found that your engine is not a early 4g63 actually, it's a late 4g63 for EVO 4-9 which the timing marks are in different position.
Anyways actually you are using the early 4g63 cam gears to set the timing in the late 4g63. To set the timing for this engine you will have to set the cam dowel pin with the "B" hole on the gears and you would need the valve cover.
And another thing I found is I think you tensioned the tensioner pulley in wrong direction, the two dots should be at around 6 o'clock.
Alright, so here we go. TDC is lined up perfectly. Rotated the motor and landed back at TDC. Pulled the pin and maintained tension. Without using the cam gear tool and pulling all slack out, I am now off half a tooth on the CAM gears. Is there any wiggle room with the cam marks?
    • dsmmario
    • Detail
    • dsmmario
    • my98gsx
