420A 420a safe at 7300rpm?
If the bottom end were balanced at a shop and had ARP rod bolts I would give it a go if I had the supporting modifications to run the motor to that extent. (But I build motors so I know who would have to fix it if it went south)
I would. I am not sure on the strength of the connecting rods or crank but would think they would do ok with a proper TUNE.
@BLACK'98DSM , do you have any info that will be helpful to this thread? You are good with the 420 motors. :)
The factory wouldn’t allow it to rev to 7,200 if they didn’t feel it was safe to do so. I’ve seen stock bottom ends spun past 8,000 without the ARPs (though I would advise them if you are going to be rough on it). The stock limiter is totally fine.
