420A 420a forged internals for cheap
DrewmHolland
171
36
Apr 11, 2022
franklin, Tennessee
I’m currently looking at turbocharging my slow 420a, I won’t be doing much I only want 7 or so psi but I figure it’s better to go ahead and rebuild my motor with forged internals to be safe. My problem right now is the price of pistons is stupid high ($700-$900) does anyone know where I could get forged internals for less?
I don't think there are any cheaper brands. The only options seem to be limited to JE and Wiseco these days. Just remember, you get what you pay for. And don't fall for the "high performance pistons" on Ebay. They are regular cast pistons, almost replicas of OE. So not forged.
You could try and find used parts but I don't recommend it unless you can handle them before purchasing. The pistons could have worn wrist pin areas and slap/knock. The wrist pins should be an extremely tight fit and require being pressed in. If they slide in by hand then the pistons are worn beyond safe use. If you order these online, you'd have no way of knowing this issue until receiving them. It's not a good idea to buy used pistons anyway.
For the rods, there's usually no major risk in getting used ones. Unless it had a horribly spun bearing and damaged a rod, but it's unlikely and the Eagle H beams are sturdy units. The rods are fairly cheap to buy new though.
The stock pistons are definitely the weakest point. The ringlands tend to break. So you could probably get away with using stock rods if your budget is really tight, though I don't recommend it of course. They are fairly tough but there's no way I would tear down a 420a to be turbocharged and re-use stock rods.
I just bought an eclipse with the 420a and previous owner put a turbo on it. He said he slapped in neon pistons which have a slightly lower compression. I don't know how true that is as I'm still learning but it's held up on 7 pounds for 10 plus years. I to am going to re buy some forged pistons and rods. I sold my setup last week not knowing I was going to end up with another non turbo. Everything happens for a reason. I may just go for a 2.4 swap who knows.
Main studs aren't really necessary unless you're looking at north of 400hp... And that's probably a conservative number. I don't see the crankshaft leaving the block at any achievable power number for your turbo setup (the crankshaft itself is a concern when the hardware is). The bed plate bolts are technically reusable but always a good idea to measure the threads and make sure they aren't stretched.
I'm not advising you against using main studs, just saying it's far from necessary on a street build. I have never installed them on any version of my engine even when the budget was there.
If you've really got extra money to spend, I'd worry more about having a way to actually tune the car :D
ARP main studs require an align-bore procedure on the crank journals at a machine shop, since they affect the clamping of the main cap. This will run another $100+ depending on what the local machine shop charges.
Honestly guys I'm glad you said something about that. I'm going to assume that's why my oil pressure was real high when I used main studs. I didn't know you had to when using main studs but now I know. I still don't know this engine very well but I'm learning.
Which turbo & wastegate?
i'm probably just gonna do the head studs since ill be pulling the motor apart in the car so I can't do any machine work
Forged pistons call for a specific piston-to-wall clearance that requires (at the very least) a hone to achieve. You won’t be able to do this yourself. If you’re not willing to take it to a machine shop, just don’t do it. This engine won’t last long.
If you are putting in pistons, they will have new rings and it will require the cylinders to be de-glazed with a hone in order for the rings to "seat" and seal. Just wanted to point that out.
I know that much, and I just honed them less than a thousand miles ago but ill do it again to be safe, as for the pistons, is their a feeler gauge set I should use to check clearances and a specfic measurement ill need for a small turbo build
thanks but engine management is kinda crazy expensive so ill just be using 93 octane and crank up fuel pressure with an fmu LOL
You need to measure the pistons diameter and then your bore diameter. Then subtract the piston diameter from the bore diameter and devide that by 2. This will give you your piston to wall clearance.
You need to go off the specs from the piston manufacturer, not the Chrysler service manual specs. Forged pistons expand more than cast factory pistons.
i've already honed my cylinders once, my block also has 220k miles on it so the pistons are gonna have a loose fit to them
The pistons wear the cylinder into an egg/oval shape. There is a reason people spend money at machine shops.
