2Gb Headlight upgrade
azdave
502
23
Nov 25, 2003
Gilbert, Arizona
Just thought I would show off a few pics of my latest lighting upgrade.
I did several upgrades including;
-Replaced the Hella E55 Fresnel lenses with ZKW replica clear lenses. This gave me a sharper cutoff line with better color too (lens was spaced out with one #8 washer under each support for best sharpness).
-Moved the old E55 lenses to the high beam positions so I now have projector-style high beams. For my real high beams I use the bi-xenon feature of the Hella E55s so the projector lens over the high beams is only to create a balanced look and it serves more of a flood light function than a high beam function. There is no room to put a true projector in that space and it's not really needed since I have 65W boosted ballasts and a bi-xenon feature on the main lamps.
-Gutted the old 1157 amber marker/turn signal bulbs and converted the turn signals to projector lenses. I then added six amber colored Rebel LEDs for a really updated turn signal look.
- Converted a set of OEM-style smoked clear reflector side markers into amber LED turn signals using 8 Lumileds SnapLEDs per side.
- Added 168 bright white LEDs to underline the entire headlamp housings. I modified some ready-made semi-flexible LED strips into two 84 LED arrays that extends along the entire lower housings. I had to modify the front lower bezels to accommodate the LEDs within the housing. The LEDs are brightness adjustable using a PWM. These lights can be activated either with the marker lights or with the fog lights. At night they are annoyingly bright so I will probably set up a dual-brightness feature so that when I turn on the marker lights they automatically dim down.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/2HujZ_hXvPg&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/2HujZ_hXvPg&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Your LED Parking lights are very unique...Do you have any plans for the rear end?! Like an LED conversion? Great work nonetheless!
Looks great AZDave.
I think the rear is already DONE! Check out his videos on youtube!
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/K6sZg3iL5EY&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/K6sZg3iL5EY&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Awesome Video!
Dave you did a hell of a job. I thought that the new Audi's with the led strip was sick, then you come along and knock it out of the park.
Yeah, AZDAVE is the LED God. He's the One! He doesn't just convert a few little things to LED like I have done to my tails, He gives it a damn flare! He is Mr. Electrode!
I'm not going to lie. I'm so jealous. Those look amazing!
He wont do anything for anyone but himself. Not in a bad way. He just does all of his stuff to be un like everyone. Plus he puts soo much soul into his work it can't be duplicated for someone else.
Will there a video to see it all in action?
More of a slide show...
  • Wanted 6 bolt NT water pipe
    • chrisman287
