2gb Headlight Lens
Sadly you cannot just buy the lens but only the complete light.
Look into restoring the lenses. You can sand then buff them with a Rotary buffer so they will look new. After that apply a sealer to keep them looking good.
no but check out the turtle wax lens restore kit... lubricant spray, a series of wet sanding sponges and buffing compund for use with a buffing wheel or power ball type. I did mine they turned out great, the hardest part was first sanding off the original fading clear coat with a medium grit painting sponge, once your down to plastic it goes quick. Comes with a lens sealing wipe, let to cure 24 hours.
I've tried cheap lens restorers without much luck - don't waste your money. Seems like you have to buff/sand to get anywhere. Good luck!
Headlightsdepot has them new for around 80 bucks with free shipping so look into that. Restores cost about $20+ and plus your time and labor, plus having down time. Iv had mine for about two years and try still look new. They did peel a little but I blame the Hids I had. It's for a set but thy do sale single as well.
