Tyler Kemp
Sep 27, 2020
Grand Rapids, Michigan
So I’m trying to start my dsm with the eprom dsmlink ecu and all i get is cranking and cranking no start. I’m also on speed density with a gm iat and 3-bar. Have gone through several settings in dsm link and also got my battery changed and alternator bench tested. I put my non-eprom 97 ecu back in and it starts right up (with issues of course). I’m stumped and don’t know why it wouldn’t start with this ecu. Any help appreciated
I figured it out. I had the input for the map as a gm 3 bar and I have a Omni 4 bar. I thought I ordered the 3 bar and I guess I got a upgrade LOL
Thank you for following up on the solution Tyler. Its always good for others to reference!
I am not sure if that tune in the ECU is for your car but alot of table have been played with in direct access. IF it was for your car then never mind, if it wasn't then it will need changes.
yeah
stuff has been changed on it already. switvhed it to omni 4 bar and still just cranks no start ill post a log
Your injector battery adjust table is ZERO that's why. Prolly not enough spraying enough fuel to ignite.
Change it to 7 volts 2295, 9 volts 1260, 12 volts 915, 14 volts 690, 16 volts 555, 19 volts 495. That is for stock injectors. Then for dead time i would guess 450-550 would be needed with those injectors.
I have precision pte lowz 1200cc injectors in the car
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
