deboelduro
- 158
- 26
- Sep 5, 2007
winsted,
Connecticut
Running a old Fp 3575 @ 42psiwhat turbo are you running? How much boost?
The 661whp I made last year at only 37psi flowing 66.1lbs @min. The car is running different set of cams and 5 more psi of boost. Here’s a pic of last years log with airflow well calibrated. 5spd carLooking at your info and log, I would think that 76lb/min would be a little more than 661whp. You auto or 5spd? Airflow numbers dead on?
I don’t have any more inputs on ECMLink to log it. I been running a aem digital fuel pressure gauge inside the car. I usually record all my pulls with the camera facing the gauges and fuel pressure is rising as it shouldAre you logging fuel pressure?
I thought of that but how would I check my afr’s on a pull to make adjustments ? The gauge tells me the pressure but switching back and forth on a pull would record either wideband or fuel pressure not both correct?Just put your fuel pressure input on a switch with your wb on the other end. Switch between inputs if you want to check fp on a pull.
