Street Build Galant vr4 #881
Ownership Status
Currently Own
Mitsubishi Galant VR-4
Turbo Type
GT40 Variant
Drivetrain
AWD
Build Type
  1. Street
Pte 6766 billet ,sls t3 manifold,jmf billet race intake manifold ,FP intake,Magnus fuel rail,fic-2150’s,dual walbro 450 pumps ,8an fuel feed and 6an return,flexfuel sensor ,fluidampr crank pulley,automotive fpr,fuel lab 818 stainless filter , speed density conversion,GM 5bar map sensor,dynatek arc 2, buschur racing 300m c.o.p kit ,Precision 46mm wastegate,Tial 50mm bov,afco racing radiator ,dual spal fans push pull setup,gsc s2 cams ,,full 3 inch down pipe and exhaust, Custom build 32x12x4 Garrett front mount intercooler,jmf fab 1g billet catch can ,e85 fed
Mods-Engine
Wiseco hd 1400 85.5mm Pistons 8:5:1 compression,Manley turbo tuff rods ,hks 1.6mm Head gasket,acl oil pump, king bearings,arp main studs,arp L19 Head studs,Gates kevlar timing belt,super tech valve seals,fp beehives valve springs, stainless valves
Mods-EMS & Logging
ECMLink v3,innovate lc2 wideband, autometer-boost,water temp, oil pressure gauges
Mods-Drivetrain
Stock transmission , act2900/6 puck sprung disk,oem clutch folk, oem throw out bearing,steel braided clutch line, brass shifter base and cable bushings,new shifter cables.
Bc e39 coilovers,Ingalls rear adjustable control arms,poly bushing everywhere,moog front & rear swaybar endlinks,new ball joints and tie rods. DD racing front & rear strut bars. Poly motor mounts inserts,17x8.5 gold wheels on 235-45 tires. 2g dual piston front calipers.
Parts Wishlist
Built transmission ,act twin disk
Background
my 1st vr4. Went all in on the build
Dyno HP
661 whp
511 lb/ft
Dyno Type
Mustang Dyno
Dyno Video Link
Watch Video
Dyno Shop Name
RRT Motorsport
Dyno Session Details
38psi,14* timing, E85
Videos
deboelduro
Share this Vehicle
