Bedicine
- 539
- 187
- Jan 3, 2022
Toronto,
ON, Canada
Hello,
Just recently switched from a S90 TB on my 2G as it was constantly whistling and had a leak. I picked up a 1g NT TB, replaced the seals in it (metal inserts), new BISS screw, bypass plate, new TPS and capped the 4 lines on the top. Did the adjustment as per the guide with the feeler gauge and such but when i started the car it is idling at 2k then climbs up to 3k. I screwed the BISS in all the way and that didnt help, loosened the TB stop and it made no change. Also when stepping on the gas then letting off the car drops idle quicks then picks it back up.
Wondering if this is because i capped the 4 lines on top of the TB instead of looping them or if its something else. Did a quick log i can upload but screenshot below. Appreciate any help.
Thank you
Thank you
