Anthony Yacullo
- 148
- 3
- Aug 20, 2014
Reseda,
California
Cleaned TB idle is at 1k right now, should I just unscrew the BISS a little?
Okay I will see whats happening.Using Link would be by far the easiest way to adjust the Biss screw. You just need to make sure the sensors are in good working order on the TB and even more important, no boost leaks. I had idle issues when I first installed Link. I found that the shaft seals on the TB shot and one fuel injector seal as well.
