Chiefsublime
5+ Year Contributor
- 61
- 18
- Oct 25, 2020
St. Paul,
Minnesota
2.3L, FP2 Cams, ECM link V3, flexfuel/SD setup, Omni 4bar, GM IAT, 1200cc FIC's, Borg Warner S300, LC2 WB, JMF SMIM, S90 TB, IAC block off, Walbro 450, Fuel lab FPR 37psi, No boost leaks, No CEL's.
I've been trying to get it to just idle so I can basically do anything with the SOB! I've tried adjusting the global dead times and pretty much anything to just get it to stay running on it's own.
I'm not sure if it's normal, but when cranking my WB 02 shows 7.4 on the gauge then starts reading (if it stays running long enough). I have to feather the throttle to keep it from dying.
I just recently noticed the alt doesn't seem to be charging or it's weak. I don't think/know if 0.1V would be enough to prevent it from idling at all though. It sucks cause I can't set the timing or even get up to the front of the car to look/listen to what's going on!!
Currently global fuel is -46.5, deadtime 355. So far these were the settings that got me closest to stay running, though I'm sure they're not right. It's a lot of maths to figure out where to set those if you're running a mix of E85 and gas. So I added more gas to run it essentially just on gas for now at least til I know it will run and get a grasp of things.
I'm new to ECMLink and EFI tuning in general. I've done a lot of reading/research though. So I feel like I have a descent grasp on the concepts any way and generally I'm pretty good at diagnostics and figuring out solutions. Though being in pretty unfamiliar territory I'll admit I'm pretty stumped. I'm hoping there's something obvious I'm missing or some value is clearly (to someone more experienced) out of whack.
Here's the last log I took having to feather the throttle to keep it running. If anyone has any insight or if I forgot to mention anything your insights would be most appreciated. Thanks!
