- Thread starter
- #26
DSMPT
DSM Wiseman
- 3,435
- 3,268
- Jun 12, 2014
Japan / Mexico,
Arizona
I started replacing the heater hoses, but ended up doing below.
- Replaced Heater hoses
- Replaced Brake booster hose and check valve
- Replaced Throttle body coolant lines
- Replaced Fuel feed line from filter to rail
- Replaced Fuel pressure regulator return line
- Replaced Intake manifold with EVO 2
- Replaced Injectors with 560cc
- Cleaned water/methanol injection nozzle and nitrous jets
- Switched the nozzle location between the water/methanol and the nitrous.
