TSimage
Supporting VIP
- 1,842
- 17
- Jan 10, 2006
Sacramento,
California
After a romp building an NSX and a Kenne Belle Ford Lightning I had the DSM bug bite me again. With my 'Mona Lisa' The Raven build being torn apart for the 3rd time after having fun driving it around on the street I figured I'd take that build even more into the 'Race' category and because of that I wanted to replace it with something a little more tame and on a more street friendly scale than a forward facing large framed turbo. So instead of an all out Beastly HX52 build this will be the smaller HX40 "Baby Beast" project.
The build break down:
-Auto (Kiggly 5 friction front clutch, Translab shift kit)
-Precision Converter
-2.3l 6 bolt built motor (9:1 compression Manley rods and pistons with Eagle crank. All parts were brand new and zero balanced and blue printed About 2K miles still on conventional 20-50 oil with oil changes every 500miles)
-1g +1mm valves
-SuperTech HD Dual springs
-FP4 cams
-Magnus V3 cast manifold
-90mm Q45 TB
-Custom full 3" exhaust with 3" V band O2 eliminator setup (DP and O2 housing are one piece) No cats
-Holset Super HX40 Pro 7 blade billet wheel BEP .70 T3 (Thanks Justin)
-FIC 1850s
-Dual Aero 340 Stealth pumps
--8an supply -6an return w/ Fuelab SS screen filter and AFPR
-Full DLink V3
-SD: 4bar omni and GM IAT
-Hallman ES MBC
-Kinetic 1000hp Race FMIC 3in/3out
-TiAL BOV
-AEM Twin Fire Ignition
-NGK BR7ES at .020
-100shot Single nozzle
Ultimate goals is to break the 600whp barrier on the Auto with the Holset, something that has never been done. Ultimately we are talking a mid 9s capable build that is geared towards street use.
Car was a bit rough when I picked her up (Car has a full 1GA Talon swap with 1GB Talon rear coming)-
and the engine bay needed attention first-
I hate clutter and I HATE dirt. I like to be bale to work on my cars with no gloves and have ZERO dirt on my hands so I went in and did a quick tuck and clean up to see if I could bare looking at it further-
Before-
After-
Some re wiring-
The VC was a bit beat up so I begin sanding it down and gettign it ready for a quick re spray-
(This pic is what it looked like BEFORE the sanding .. yeah it was that beat...)
Purp!
Couple more layers-
Definite improvement (letters still need to be polished)
Naturally at this point I knew more needed to happen. The 3065 was epic but I wanted a bit more top end and above all else I needed to get rid of the 5spd because "I've been there.. done that, and never again.."
More pics to come of the tear down.
-1g +1mm valves
-FP4 cams
-90mm Q45 TB
-FIC 1850s
-Full DLink V3
-Hallman ES MBC
-TiAL BOV
-NGK BR7ES at .020
Before-
After-
Some re wiring-
Purp!
Couple more layers-
